DJ: Hercules DJ RMX vs M-Audio Torq Xponent vs ?
Discussion in 'Musicians' started by walker_2003, Sep 20, 2010.
  1. walker_2003
    walker_2003 Member
    Jan 15, 2003
    13,280
    Hello, Any1 here had a chance to use both?
    The Xponent looks awesome but is like $500 more then the Hercules..
    Or is there any other Sub $1000 MIDI's you recomend?
    walker_2003
    walker_2003 Member
    Jan 15, 2003
    13,280
    If the budget permits the Traktor Kontrol S4 looks insane...
    $1200 tho :S
  3. Remote Man
    Remote Man Member
    Jul 23, 2002
    1,035
    Melbourne.vic.au
    With the current exchange rate. Landing a S4 from the US is a sub $1000 excursion.
    That said it's not out yet and the exchange rate could collapse.
  4. BassKat
    BassKat Member
    Mar 23, 2005
    305
    VCI100 with Traktor is pretty good too. Check out some youtube vids and see what people can do with it.
  5. Remote Man
    Remote Man Member
    Jul 23, 2002
    1,035
    Melbourne.vic.au
    Actually just check out http://www.djtechtools.com that's everything you ever need to know about digital djing
  6. ^catalyst
    ^catalyst Member
    11,978
    melbourne
    S4 looks dope, can't wait to try one.
    Personally, I'd be interested in a VCI + Kontrol X1 with traktor, that would be sick.
  7. DJ Fusion
    DJ Fusion Member
    Mar 7, 2003
    4,946
    If your budget starts getting that close to $1,000 you'd be mad not to seriously consider a couple of 1200's with Serato imo.
  8. bubblegoose
    bubblegoose Member
    May 18, 2007
    4,508
    Molesworth - Tasmania
    lol that guy in the video looks/acts like such a tool. :lol:
  9. ^catalyst
    ^catalyst Member
    11,978
    melbourne
    Just watched that video, must stop watching S4 media.
  10. quacka
    quacka Member
    Aug 24, 2003
    4
    Depends on which software you wish to use with it.
    xponent - torq
    vestax vci 100 - traktor
    RMX - virtual dj
    download a copy of each and play around iwth it before you choose.
    torq is noobie friendly, virtual dj is in between and traktor is more advance imo.
    I personally chosed the xponent as torq is easy to use, it has a great sound card, and all the buttons on the controller are lit up so it is great in the dark.
    The new traktor control s4 looks great though if you can afford it :)
    walker_2003
    walker_2003 Member
    Jan 15, 2003
    13,280
    Im pretty good with virtual DJ and I know how to create the macro thingies..
    The xponent looks good, maybe the traktor is overkill for my music tastes (trance/house)
  12. ^catalyst
    ^catalyst Member
    11,978
    melbourne
    Traktor fucking rocks for 4/4, anything like trance / tech-house / techno etc.
    I play mainly dubstep and I don't get heaps of play out of all the traktor features, but when I'm mixing 4/4 I really get into loops and effects and shit.
    Awesome with the little X1 controller and a set of turntables.
    walker_2003
    walker_2003 Member
    Jan 15, 2003
    13,280
    so whats the next step down from s4 traktor pro?
  14. ^catalyst
    ^catalyst Member
    11,978
    melbourne
    Traktor Pro and a controller of some sort, Native Instruments only make the S4 as far as controllers go.
    Vestax? Behringer BCD?
    If I was in your shoes, I'd probably grab a BCD3000, comes with Traktor DUO or something, which is AMPLE to learn on. Can plug turntables/other shit into it aswell. Later you can upgrade to Traktor Pro if you like.
  15. Modafroman
    Modafroman Member
    Jul 10, 2002
    10,057
    What do you guys think of the Vestax Typhoon/Spin? Other than the stupid eq setup with sliders and not knobs, and no eq kills, it looks like a damn nice piece of equipment. Anything else I should be looking in the ~$300-400 range? (Would be used with Traktor, as i'm used to it).
  16. ^catalyst
    ^catalyst Member
    11,978
    melbourne
    OKOK.
    You do not need full kill EQ's.
    I've got them on my Ecler and I actually don't like them- Very easy way to make a mix sound shit.
    Full kill EQ can be rigged up in Traktor aswell by using the NUO preset for EQ.
    Filters also are more useful than full kill eq.
    $300-400 puts you in the range for some Hercules, Vestax and Behringer products. I think the Vestax is probably the best, but it depends on you.
    -Lachie
  17. Remote Man
    Remote Man Member
    Jul 23, 2002
    1,035
    Melbourne.vic.au
    Kills are for scratchin' and rollin' yo!
    And yeah the Vestax is one of the better bits of kit if you want have the skills to go and play out on CDJs
  18. Modafroman
    Modafroman Member
    Jul 10, 2002
    10,057
    Unfortunately not all of us bedroom spinners can afford cdjs :p
    I'm really rather tempted by the Vestax Typhoon actually, sigh :s
  19. Remote Man
    Remote Man Member
    Jul 23, 2002
    1,035
    Melbourne.vic.au
    Yeah I know. I can't afford CDJs either, what I was saying is the Vestac is going to have some of the features of CDJs (2 part platter mainly) that if you can learn to beatmatch on (please learn to beatmatch I didn't and I'm kicking myself for it). Make the transition to CDJs easy (say if you play at a bar/club for a friends birthday or a rich friend lets you have a spin)
