DNS issue with Telstra IP reaching Telstra NS
Discussion in 'Networking, Telephony & Internet' started by Sleepyz7z, Mar 1, 2019.
  1. Sleepyz7z
    Sleepyz7z Member
    Mar 16, 2016
    32
    Could any folk on a Telstra connection of some description (IPv4) run the following:
    nslookup beyondblue.org.au ns1.telstra.net
    (should be same command format whether windows/linux/macOS)
    and report if it resolves or times out? First 2 octets of your IP and location would be good!
    Background: have several pfsense boxes and in their default config, use unbound for DNS. Two are on Telstra connections and cannot resolve certain domains. Others, which use a mix of providers, are fine. Debug shows affected domains which use the above nameserver are timing out to queries from certain Telstra IPs (at least two Telstra connections in Adelaide, both 101.166.x.x). Doesn't appear to be routing related as they can ping/trace to ns1/0.telstra.net fine
    Thanks ladies & gents
  2. caspian
    caspian Member
    Mar 11, 2002
    11,547
    C:\>nslookup beyondblue.org.au ns1.telstra.net
    Server: UnKnown
    Address: 139.130.4.5
    Address: 203.32.14.130
    no delay in response.
    cpe-121-219-xxx-xxx.bpwi-r-031.win.vic.bigpond.net.au, so hanging off a LAC in Windsor, Melbourne.
  3. waltermitty
    waltermitty Member
    Feb 19, 2016
    1,450
    BRISBANE
    Do you have DNS forwarding on or is Unbound resolving and not just caching? If so, which fwders?
    Sleepyz7z
    Sleepyz7z Member
    Mar 16, 2016
    32
    No forwarding on (default config, so unbound is doing all the resolving).
  5. evilasdeath
    evilasdeath Member
    Jul 24, 2004
    4,984
    Well, am on telstra and i can't even dns query the telstra name servers! (i dont use them normally) can query other name servers fine, yet i can ping both name servers? what the?
    can't even resolve google/telstra whatever
    melbourne 121.211
  6. Nobby6
    Nobby6 Member
    Oct 25, 2017
    151
    S.E.Q
    139.130.4.5 is not a recursive server, it's an authoritative, it wont resolve domains its not serving.
    try 139.130.4.4 thats recursive.
    That said, 4.5 is authoritative for, and resolves, beyondblue.org.au
  7. evilasdeath
    evilasdeath Member
    Jul 24, 2004
    4,984
    yeah i guessed it was not recursive, but it does not respond to nada.
    no dns reply period for any zone, not even beyondblue.org.au yet i do see it is delegated to those servers. Usually i would at least see a recursion not available.
    looks like they block direct queries from IP ranges to stop people.
  8. Nobby6
    Nobby6 Member
    Oct 25, 2017
    151
    S.E.Q
    OK, I've never looked for a PM here so if it does exist ,if you want to let me know what (121.211. x.y) the x is - I dont want to know your class c (the y, keep that to yourself), and I'll see what can be done
  9. evilasdeath
    evilasdeath Member
    Jul 24, 2004
    4,984
    121.211.43
    Telstra HFC, melbourne
    looks like sleepy op also has some ips blocked.
    But yeah icmp is fine to both ns0/ns1
    however digs to either fail for authoritive/non authoritive zones result in timeouts.
    Sleepyz7z
    Sleepyz7z Member
    Mar 16, 2016
    32
    Not getting 'refused' either, just silently dropped. Problem reports first came in a month back.
    Are you in the 'Big T' machine, Nobby6? (work or have connections to Telstra?)
  11. Nobby6
    Nobby6 Member
    Oct 25, 2017
    151
    S.E.Q
    It seems there was some migration problems, should be fixed now, can you guys check to see if its all good please?
    Sleepyz7z
    Sleepyz7z Member
    Mar 16, 2016
    32
    No dice 101.166.199.x and 101.166.206.x
  13. Nobby6
    Nobby6 Member
    Oct 25, 2017
    151
    S.E.Q
    which domains, just beyondblue?
  14. evilasdeath
    evilasdeath Member
    Jul 24, 2004
    4,984
    This is what i get from the 2 telstra servers from behind my home Telstra HFC service
    Code:
    $ dig @ns0.telstra.net beyondblue.org.au
    ; <<>> DiG 9.11.3-1ubuntu1.5-Ubuntu <<>> @ns0.telstra.net beyondblue.org.au
    ; (1 server found)
    ;; global options: +cmd
    ;; connection timed out; no servers could be reached
    dig @ns1.telstra.net beyondblue.org.au
    ; <<>> DiG 9.11.3-1ubuntu1.5-Ubuntu <<>> @ns1.telstra.net beyondblue.org.au
    ; (1 server found)
    This is what i get from another DNS server i manage. So it does work.
    Code:
    dns1:/# dig @ns0.telstra.net beyondblue.org.au
    ; <<>> DiG 9.11.3 <<>> @ns0.telstra.net beyondblue.org.au
    ; (1 server found)
    ;; Got answer:
    ;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 56857
    ;; flags: qr aa rd; QUERY: 1, ANSWER: 1, AUTHORITY: 2, ADDITIONAL: 1
    ;; WARNING: recursion requested but not available
    ;; OPT PSEUDOSECTION:
    ; EDNS: version: 0, flags:; udp: 4096
    ;; QUESTION SECTION:
    ;beyondblue.org.au.             IN      A
    ;; ANSWER SECTION:
    beyondblue.org.au.      300     IN      A       203.32.14.130
    ;; AUTHORITY SECTION:
    beyondblue.org.au.      3600    IN      NS      ns1.telstra.net.
    beyondblue.org.au.      3600    IN      NS      ns0.telstra.net.
    ;; Query time: 15 msec
    ;; SERVER: 139.130.204.47#53(139.130.204.47)
    ;; WHEN: Wed Mar 06 14:12:36 EST 2019
    ;; MSG SIZE  rcvd: 109
    dns1:/# dig @ns1.telstra.net beyondblue.org.au
    ; <<>> DiG 9.11.3 <<>> @ns1.telstra.net beyondblue.org.au
    ; (1 server found)
    ;; Got answer:
    ;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 59812
    ;; flags: qr aa rd; QUERY: 1, ANSWER: 1, AUTHORITY: 2, ADDITIONAL: 2
    ;; ANSWER SECTION:
    ;; ADDITIONAL SECTION:
    ns1.telstra.net.        3600    IN      A       139.130.4.5
    ;; Query time: 3 msec
    ;; SERVER: 139.130.4.5#53(139.130.4.5)
    ;; WHEN: Wed Mar 06 14:12:40 EST 2019
    ;; MSG SIZE  rcvd: 125
    Sleepyz7z
    Sleepyz7z Member
    Mar 16, 2016
    32
    Literally anything ns(x).telstra.net is authoritative for. I used google-fu to find a list of 10,000 domains e.g. davidjones.com.au, batteryworld.com.au etc. and they're all affected due to the fact there seems to be dropping of requests from certain addresses.
    Pretty much as evilasdeath reports above.
  16. Doc-of-FC
    Doc-of-FC Member
    Aug 30, 2001
    3,383
    Ausnog post yet?
    Just saying ;)
  17. Nobby6
    Nobby6 Member
    Oct 25, 2017
    151
    S.E.Q
    You will get kicked pretty kick for end user complaints on ausnog :)
    since its responds to ping, its not a routing issue.
  18. Nobby6
    Nobby6 Member
    Oct 25, 2017
    151
    S.E.Q
    Can I get traceroutes please of the Vic and SA HFC connections, looking for a common factor, there has been some rate limiting going on due to some lamer trying a DoS on that name, but thats only been going not even a week, so is unlikely the issue given you never get an answer and I get an answer everytime, as did Caspian who's in a different state.
    Sleepyz7z
    Sleepyz7z Member
    Mar 16, 2016
    32
    I didn't think to compare traceroutes from working/nonworking to be honest, as I could ping the server I pretty much thought the path wasn't a problem.. but maybe it is.
    Code:
    Tracing route to ns0.telstra.net [139.130.204.47]
    over a maximum of 30 hops:
      1    <1 ms    <1 ms    <1 ms  firewall.box [192.168.1.1]
      2     *        *        *     Request timed out.
      3    11 ms    31 ms    12 ms  10.63.53.131
      4    43 ms    34 ms    54 ms  10.195.185.50
      5     *        *        *     Request timed out.
      6     *        *        *     Request timed out.
      7    29 ms    31 ms    30 ms  203.50.245.241
      8    42 ms    30 ms    39 ms  ns0.telstra.net [139.130.204.47]
    Tracing route to ns1.telstra.net [139.130.4.5]
      3    12 ms    12 ms    12 ms  10.63.53.131
      4    18 ms    18 ms    34 ms  10.195.184.170
      7    21 ms    21 ms    31 ms  203.50.243.241
      8    23 ms    22 ms    20 ms  ns1.telstra.net [139.130.4.5]
  20. caspian
    caspian Member
    Mar 11, 2002
    11,547
    if you can ping the server then you have connectivity to it, that's all a traceroute is going to show you in that regard.
