Do I need Vlans? Help for this noob please.
Discussion in 'Networking, Telephony & Internet' started by Niggle, Feb 2, 2019.
  1. Niggle
    Niggle Member
    Jul 1, 2001
    327
    Sydney, Australia
    What I am trying to do is I have multiple small networks (5+) with 4 devices (connected wirelessly) on each and then assign an ip to each network by using either vpns or proxys. Vpns or proxies must be done at the router level. Now I've made 1 extra network by connecting an asus router into the back of my main internet router and then entering the vpn details into it. This has given me one extra network but I need more and buying 5+ routers is going to be a little expensive. Is there a wireless router that could do all this for me in 1 unit?
  2. davros123
    davros123 Member
    Jun 18, 2008
    2,930
    You do not need multiple routers. You want one router, (and probably one Access point).
    Decent access points (AP's) like ubiquity are cheap, solid and can do multiple vlans. (vlans run over the same wire and are *basically* just logical separation of traffic. They do not have to be different subnets, but usually are)
    Just setup the 5 or so vlans (each with it's own dhcp) on your router and run the multiple vlans into a (single) AP - such as ubiquity unify AP. It has multiple wifi networks, one on each vlan. I do this for guest access and my main LAN access.
    Your router is probably shit, so I'd grab the ubiquity edgerouter x @ $85 (https://www.scorptec.com.au/product/Networking-Wired/Routers/66592-ER-X-AU) and one (or more if you REALLY need it - likely coverage will be fine with one) UAP AC Lite @ $139 (https://www.scorptec.com.au/product/Networking-Wireless/Access-Points/61350-UAP-AC-Lite-AU - you do not need the pro, the lite's are fucking awesome.
    $224, done. Sell Asus and profit.
    Niggle
    Niggle Member
    Jul 1, 2001
    327
    Sydney, Australia
    Thanks for the reply! Its much appreciated! How many vlans would this setup be capable of?
  4. davros123
    davros123 Member
    Jun 18, 2008
    2,930
    Good question. Each AP can have max 8 SSID's per radio, so 8 for 2.4 and 8 for 5Ghz. You can have each AP have a different set of 8 (groups they are called).
    The router is basically unlimited...well, 4095 but hey...that IS the limit.
    I just added 6 test networks (I did not bother to add the vlan ID to them, but that's just part of the config screen - see below).
    Niggle
    Niggle Member
    Jul 1, 2001
    327
    Sydney, Australia
    The link to the ubiquiti AP that you have kindly provided above advertises itself as a dual radio. I would assume that's 2.4ghz and 5gz. Does that mean 8 vlans for 2.4ghz and 8 vlans for 5ghz for a total of 16?
  6. davros123
    davros123 Member
    Jun 18, 2008
    2,930
    yes, see my reply above :)
    The 8 networks int he the pic I posted are all AC. Could also do the same for 2.4
    Niggle
    Niggle Member
    Jul 1, 2001
    327
    Sydney, Australia
    Does the ubiquiti settings/firmware have the facility to assign a separate VPN for each vlan?
  8. davros123
    davros123 Member
    Jun 18, 2008
    2,930
    what do you mean vpn? vpn to where and why? What are the end points you are trying to connect via a vpn. Can you post more info on what you are trying to do. multiple vpn's like this sounds plain weird.
    Niggle
    Niggle Member
    Jul 1, 2001
    327
    Sydney, Australia
    What I am trying to achieve is multiple vlans with their own unique ip address on the Internet. Could I purchase a number of USA (or whereever) VPN connections and connect each one to each vlan giving each a unique internet ip?
  10. davros123
    davros123 Member
    Jun 18, 2008
    2,930
    Sure. The router x can handle multiple vpn's. Just hook each vpn into the vlan and presto. Weird though.
    What's it for? Something naughty i hope:)
    Niggle
    Niggle Member
    Jul 1, 2001
    327
    Sydney, Australia
    Haha. Nothing sinister or naughty. Its a money making app I use where multiple connections would be a huge advantage for me. I'm happy to discuss if interested.
  12. Quadbox
    Quadbox Member
    6,230
    You know there's no need to actually do that on seperate devices or faff about with your home network at all, really, if it's just one app you're trying to have multiple instances of each talking via a different vpn. One of probably a million ways of doing it would just to run multiple minimal VMs on the one computer and have each VM connected to a different vpn...
  13. RyoSaeba
    RyoSaeba Member
    Sep 11, 2001
    12,405
    Yeh, don't even need any vlanning at all. Multiple VMs running off 1 PC, all connect to different VPNs and that'll be fine.
    Niggle
    Niggle Member
    Jul 1, 2001
    327
    Sydney, Australia
    I can't use VMs. I need to use physical devices. Thanks for the input though
  15. Quadbox
    Quadbox Member
    6,230
    Surely you could just mac spoof each vm. What physical property is being tracked here?
  16. waltermitty
    waltermitty Member
    Feb 19, 2016
    1,018
    BRISBANE
    OP are you a cam girl on multiple sites?
    Matthew kane and Pugs like this.
    Niggle
    Niggle Member
    Jul 1, 2001
    327
    Sydney, Australia
    Lol no! I'm doing what is known as phone farming. You can search for it on youtube for some good info but its basically running apps on many phones at once that pay you to have them running on them. The companies that run the apps pay you to show ads on your devices.
  18. waltermitty
    waltermitty Member
    Feb 19, 2016
    1,018
    BRISBANE
    Wow, $1 per month, that looks like such a great idea!
    Niggle
    Niggle Member
    Jul 1, 2001
    327
    Sydney, Australia
    More like $200-$300 a month. Not too bad for about 10 minutes work a day.
  20. davros123
    davros123 Member
    Jun 18, 2008
    2,930
    nice. money for jam.
