Document Management Systems
Discussion in 'Business & Enterprise Computing' started by nitro_jawt, Aug 27, 2010.
  1. nitro_jawt
    nitro_jawt Member
    Dec 11, 2004
    344
    Hi all, we're looking for a document management system that can provide workflow management, access approval, version control etc. Does anyone have any experience with products that might fit this that they would recommend?
    Thanks.
  2. power
    68,340
    What about Sharepoint?
  3. Search
    Search Member
    May 9, 2004
    95
    2000
    nitro_jawt
    nitro_jawt Member
    Dec 11, 2004
    344
    Not sure about budget, will depend on what can be justified, but I'm going lean towards the smaller side if history tells me anything. Around 100 staff.
    Sharepoint is certainly an option, but there must be others out there...
  5. yoda123
    yoda123 Member
    Apr 17, 2003
    2,791
    QLD
    Fuji Xerox - Docushare
  6. elvis
    elvis Old school old fool
    46,639
  7. SingAlong
    SingAlong (Banned or Deleted)
    May 30, 2010
    474
    Sydney 2035
    I can't seem to find the Open Source version on that site... do you know where it is located? :thumbup:
  8. elvis
    46,639
  9. bugayev
    bugayev Whammy!
    May 15, 2003
    4,092
  10. SingAlong
    May 30, 2010
    474
    Sydney 2035
  11. exodus_68
    exodus_68 Member
    Jun 10, 2003
    354
    You have a lot of options. In the case of EDMS there really is no product that is going to do everything, especially not 'straight off the shelf'.
    You will really need to decide what the overall budget is for the project before you can make any decisions on possible products. Keep in mind you need to budget for development and customistaion as well as user training, on top of the expense of the product if you chose a pay-for product.
    Currently we have a product in place called Recfind and I can't say I would recommend you race out to purchase that one...it is quite unfriendly for the user and the management side is not particularly impressive.
    You could look at options like Trim or Hummingbird which are sold as off the shelf products, cost a lot of money, and will need customisation and development to fit an organisation. Alternatively you look at Sharepoint and MOSS but you will also need to spend a good amount on development on top of the cost of the product.
    As Elvis suggested there is KnowledgeTree community, plus others likes Joomla and Plone all of which have community versions and all of which will require significant amounts of development...but of course you won't have to buy them in the first place.
  12. kbekus
    kbekus Member
    Aug 28, 2001
    1,255
    Pascoe Vale, Melbourne
    lots of choices I've admin'd/used : Lotus Domino.Doc, Trim (best I've used), RecFind, Sharepoint.
    how much money do you have to spend? how long to implement?
  13. g1g@8yT3
    g1g@8yT3 Member
    May 30, 2003
    104
  14. narkotix
    narkotix Member
    Oct 8, 2003
    518
    Trim or hummingbird...
  15. barbz
    barbz Member
    Dec 12, 2006
    271
    We use Interwoven/Autonomys Worksite or Desksite.
    The client integrates with outlook which makes life easy for staff, it also does email management and given its bolted into outlook makes it a no brainer for staff to profile in/out bound emails.
    Weve being on it for the last 6 years with close to 3 million docs from 110-120 staff. Its not cheap but works brilliantly.
    They also have mobile clients for i devices and blackberries.
    Let me know if you want any extra information.
    Paul
  16. wipeout
    wipeout Member
    Dec 29, 2001
    1,669
    Sydney, Australia
    As others have said, there are many enterprise content management solutions on the market. Selection will depend on your requirements, however I've noticed the leading open source vendor hasn't yet been mentioned: http://www.alfresco.com/
  17. DanWA
    DanWA Member
    Oct 15, 2006
    1,445
    W.A
    trim is a piece of shit for end users but easy to admin :)
  18. Rampage101
    Rampage101 Member
    2,034
    Country NSW
    DanWA - Why? We're looking at possibly migrating from Bluepoint (Lotus Database) to Trim down the track.
  19. Nyarghnia
    Nyarghnia (Taking a Break)
    Aug 5, 2008
    1,274
    To the OP, some questions that you need to think about and / or post here :)
    A) Size of your organisation, one office, more offices, 10 staff.. 50 staff... thousands of staff... how many of them will need to interact with this system? This is an important thing to know, because it will partially dictate the type of solution you are looking into, you may come across a good product, but then find it really can't handle much more than 10 or 20 people logged onto it at once, converesly you don't want to overkill the problem with a system that is designed for thousands of concurrent users if you've got a head office with only 10 or so people in it...
    B) Nature of 'documents' to be stored... are we talking purely user created documets, system or application generated documents (be they letters, reports and so forth), this - I suppose - is really defining what you mean by the word... 'document'.
    C) Volume of documents, how many do you need to store? What sort of growth rate in documents do you anticipate? Are you looking at keeping various copies of documents over time or something that uses differentials to reduce space? This is important because you need to make sure your selected solution can scale properly, there's no point implementing a solution that will need to be replaced inside 3 years.
    E) Access, how do you want people to access the documents? Do you need to provide access to internal staff only, or to 3rd parties & customers? Who will be the 'consumer' of any such system and what are their expectations? Intranet, extranet, customer service portal, or client software?
    F) Security? How important is security and auditing? Do you want to restrict what documents can be seen based on user security privileges? Do you need to log who has worked on or viewed which documents and at which time?
    This is CRITICAL in any environment where privacy laws may be in effect and documentation is covered by the privacy act. Seriously the last thing you want to be involved in is some for of legal discovery process and have a lawyer ask you to provide names, dates and times at which a contolled document was accessed and only to be sitting there with your jaw hanging open going 'duuuuuuh, i dunno'.... not a good look.
    Only when you have sat down and answered these (and other) questions can you then begin to draw up a list of products on the market and begin speaking to 3rd party vendors and / or consultants about selecting candidate systems.
    -NyarghNia
  20. geniesis
    geniesis Member
    Aug 27, 2007
    191
    Take a look a webparts360.
    www.webparts360.com
    It leverages off sharepoint, and provides a much better interface for you to be able to manipulate work flows, database interactions and custom logic.
    There are several flash videos on the site demonstrating the product in action.
