Dolby Atmos, is it Worth it?
Discussion in 'Audio Visual' started by Court Jester, Aug 29, 2017.
  1. mils1
    mils1 Member
    Jul 17, 2005
    1,045
    Selected titles, you also need to download the Dolby app on the one s for it to work. You need to see atmos displayed on receiver, it sounds good if you have a 7.1.4 or 5.1.4 setup. In ceilings speakers work best for atmos.
  2. Copie
    Copie Member
    Jul 24, 2009
    14,546
    Newcastle
    And the device needs to support audio passthrough via hdmi.
  3. Madengineer
    Madengineer Member
    May 27, 2011
    14,614
    Yeah I just saw that I needed that App when I went digging...
    What's 5.1.4?
    The Xbox One S does.
  4. Copie
    Copie Member
    Jul 24, 2009
    14,546
    Newcastle
    5 satellite speakers (inc 1 center) 1 subwoofer and 4 atmos speakers (vertical firing or downward firing)
  5. mils1
    mils1 Member
    Jul 17, 2005
    1,045
    5 is your speakers, 1 is the sub and 4 is your atmos speakers.
  6. Madengineer
    Madengineer Member
    May 27, 2011
    14,614
    But still only 5 physical speakers right? (I've never heard of 5.1.4 :S)
  7. Copie
    Copie Member
    Jul 24, 2009
    14,546
    Newcastle
    No.
    9 physical speakers.
  8. Madengineer
    Madengineer Member
    May 27, 2011
    14,614
    Well that's out then. haha
    I'll have to look into how that's even possible with my amp...
  9. Copie
    Copie Member
    Jul 24, 2009
    14,546
    Newcastle
    Depends on the amp, most mid range AV recievers can accept additional power amps to give you more outputs.
    But unless you can fit speakers into the roof space, atmos isnt really worth it. Same with 7.1/9.1 or .2 unless the room is huge.
  10. Madengineer
    Madengineer Member
    May 27, 2011
    14,614
    Yeah I can't. Not yet. It'll be something to keep in mind though. I'm going to try and upgrade the current speakers I have before I go buying additional.
  11. Copie
    Copie Member
    Jul 24, 2009
    14,546
    Newcastle
    Good speakers first. Plenty of options around both new and 2nd hand. I am happy with my Yamaha speakers with Paragrim 12 inch woofer. Though if i bought again i would get SVS speakers/sub.
  12. Smoke87
    Smoke87 Member
    Jun 17, 2005
    6,195
    Windows 10 supports Dolby Atmos now, but switch back to bit stream 7.1 if you're listening to stereo content. I've found my receiver makes the dialogue incredibly boomy with Windows Atmos enabled. Switching back to Stereo isn't available when Windows 10 says the audio is Atmos-only.
