Doom 4
Discussion in 'PC Games' started by hot_sparx, Jun 16, 2008.
  1. mesaoz
    mesaoz Member
    Jan 15, 2015
    8,387
    South East QLD
    Can you enable shadow copies on the save file directory?
  2. cvidler
    cvidler Member
    16,356
    Reading the Steam/Bethesda forums it seems like almost everyone is having the problem. Yet they still won't recognise it as a problem / solution is to delete your saves and start again. Seems it's a bullshit 'feature' and poorly implemented (who cares if someone cheats in the SP mode, or while building snapmaps).
  3. NSanity
    NSanity Member
    Mar 11, 2002
    18,659
    out of curiosity - are people using start options - potentially disabling the disabled M_smoothing and enabling U-N.
  4. PsychoSmiley
    PsychoSmiley Member
    Dec 23, 2001
    7,235
    Taranaki, New Zealand
    I'm using absolutely nothing in my case. I did have disable the startup videos but that didn't really do anything since they seem to use that time to load game files anyway so it just sat at a black-ish screen wile it loaded.
    My annoyance is that it's really easy to trigger and it seems they've done nothing to protect the game from Dev mode. It should be triggered by a specific launch parameters, not from a game crash or accidentally opening the console.
  5. cvidler
    cvidler Member
    16,356
    First time it happened to me, I had startup options set (skip intro video), but thrice since, nothing. disabled steam sync, followed all the 'fixes' in the forums. it's definitely a bug in the game. I also get the crash to desktop bug too.
    I'm hoping they come out with a fix soon. I don't want to have to restart again until I know it's fixed. currently I'm just playing through with the problem. It was a good diversion while I was off sick last week.
  6. cvidler
    cvidler Member
    16,356
    dev mode appears (going from the logs I can find) has nothing to do with start up options, or people hitting ~ key. It happens when trying to load a corrupt save game. If it happens to you, hit the ~ button when you first get the error message, and check the console log, a few lines up in yellow it'll say loading unverified save game.
    The problem - and what needs to be fixed - is whatever is corrupting the save games. I've had it happen after a crash to desktop, I've also had it happen when successfully closing the game via the 'exit to desktop' menu.
  7. mesaoz
    mesaoz Member
    Jan 15, 2015
    8,387
    South East QLD
    Tried whitelisting the file/directory in your AV?
  8. PsychoSmiley
    PsychoSmiley Member
    Dec 23, 2001
    7,235
    Bethesda's basically blame it on everything but the game though which is shit. They just need to fix the damn problem.
  9. Sphinx
    Sphinx Member
    Sep 16, 2001
    10,722
    I have the following launch options set, since day 1 - no problems, using 2 different save slots:
    But I have had no crash to desktops (running latest nvidia drivers on 980Ti)
  10. cvidler
    cvidler Member
    16,356
    you're one of the few lucky ones.
  11. Frogloose
    Frogloose (Banned or Deleted)
    Apr 17, 2016
    420
    Hi,
    No problems for me from day 1, even over 2 different PC's with completely different configurations.
    Just finished it this afternoon, final boss was disappointing, wasnt much of a challenge.
    Good game, but i dont think its worth 45-60aud, maybe 30aud.
    Cheers
    Frogloose
  12. GregDude
    GregDude Member
    Aug 12, 2002
    1,310
    Not necessarily cause and effect, but after updating to latest nvidia drivers, I've had 2x crash to desktop.
  13. PsychoSmiley
    PsychoSmiley Member
    Dec 23, 2001
    7,235
    Trawling the sound files looking for the 'secret found' riff for a message tone for my phone. I find it I'll link it here in case any of you want it.
  14. mesaoz
    mesaoz Member
    Jan 15, 2015
    8,387
    South East QLD
  15. mesaoz
    mesaoz Member
    Jan 15, 2015
    8,387
    South East QLD
    Cyber demon was really easy... hmm.... Died once in the second phase because I didn't know it existed so I was fucking around.
    Should have had base level enemies spawning in the room at the same time.
  16. greenhawk
    greenhawk Member
    Dec 18, 2003
    791
    Translation - it is a DRM feature.
    While it does seem like a stupid feature, it probably exists so people do not hack the saved game files to get things.
    It definitely seems well past the period where you could get a game and do what you want with it.
  17. havabeer
    havabeer Member
    Dec 12, 2010
    7,347
    is this one of those games i could just grab all the steam files from someone else and just copy it over into my own steam folder
    i have bought the game just not looking forward to downloading 45gig
  18. NSanity
    NSanity Member
    Mar 11, 2002
    18,659
    Yes.
    Being a steam game, Its like every single Steam Game in existence.
  19. Sphinx
    Sphinx Member
    Sep 16, 2001
    10,722
    Maybe, not sure considering the DRM enforcement technology being used (as discussed a few pages back) certainly isn't the norm - as it downloads executable binary code specific for your CPU revision when it is initialized.
  20. miicah
    miicah Member
    Jun 3, 2010
    7,694
    Mount Cotton, QLD
    My GTX660 will apparently get me roughly 25fps on Ultra, is it worth spending somewhere around the $100 mark (after selling it) to upgrade to a 280x? Benchmarks seem to indicate it can get close to 50fps on Ultra, and 70fps on medium.
