Double-wide frying pan
Discussion in 'Geek Food' started by s3kemo, Oct 24, 2012.
  1. s3kemo
    s3kemo Member
    May 13, 2003
    5,889
    in a house
    Hey guys,
    Maybe my google skills aren't so good this morning, but I'm after a frying pan that's rectangular to cover 2 hotplates on the stove. Reason being, I like to cook my bacon/eggs/mushrooms in one pan and cooking for more than 1 is hard... and I hate juggling frying pans. Plus it's easier to have a 'warm' side for the side that sits over an off burner, and a hot side to cook what's left to cook.
    Anyone know of any brands/websites that I can take a look at? It's just a rectangular frying pan with a handle... I thought they'd be easier to find than this :(
    inb4 use the bbq. I'm talking about inside for this one. Shuffling things around on the one bbq hotplate is super easy, so I want to do the same inside.
    Thanks!
    edit: kinda like this but with a handle if possible - http://shop.myer.com.au/shop/en/mye...ed-grill-and-plate-50cm-extra-large-975741770
  2. looktall
    Sep 17, 2001
    26,733
  3. Zuby
    Zuby Member
    Sep 5, 2001
    570
    Have a look for teppenyaki plates, they are large rectangular ones like the one you linked. Should be able to find them a lot cheaper than that too. However, never seen any with a frying pan handle...that would be some serious amount of weight to lift with a handle!
  4. broccoli
    broccoli Member
    Feb 21, 2010
    21,502
    Yes, I doubt you'd find those big grill plates with a frying pan type handle. Not only wouldn't you be able to lift it (especially if cast iron), but it wouldn't be safe. A frypan can have the handle turned to the side, but that would by necessity have it sticking out the front which would be a kitchen hazard. I think you'd only ever find those handles at the sides like the one you linked to.
    s3kemo
    s3kemo Member
    May 13, 2003
    5,889
    in a house
    Thanks for the replies guys.
    The reason I want a handle is I wash my pans immediately after cooking... helps get the oil off while the pan is still hot.
    So I guess the size of the handle isn't important but I was hoping to be able to grab it without a mitten.
  6. broccoli
    broccoli Member
    Feb 21, 2010
    21,502
    Even if you could lift it, the balance would be way out of whack with something that size. I've got the chasseur crepe pan and it weighs a ton. The big grill plate would only be two-hand lift, for sure. It's an opportunity to buy some good oven mitts - shopping time. :thumbup:
  7. RyoSaeba
    RyoSaeba Member
    Sep 11, 2001
    13,336
    It's generally recommended not to wash your pans while they're still hot. Cooling steel quickly is generally not a good idea due to expansion and contraction. So says my Le Chasseur instructions. :D
  8. Romen
    Romen Member
    Mar 14, 2003
    2,587
    Adelaide, SA
    Yep.. causes the cookware to bow.
  9. Stooge007
    Stooge007 Member
    Aug 22, 2006
    11,824
    The Shire, Sydney
    pretty sure i've seen some large electric frypans?
    s3kemo
    s3kemo Member
    May 13, 2003
    5,889
    in a house
    The handle isn't so much for moving it around (like, say shuffling a pan to stir the ingredients) as much as it's for holding it still on the pan or for maneuvering it around the sink to clean it while it's still hot.
    Sorry, meant to say I use hot water. Cold water just makes oil solidify, so hot water is the only way it works.
  11. broccoli
    broccoli Member
    Feb 21, 2010
    21,502
    Those big grill plates won't be moving. The instructions do say to let them cool down before wetting (hot or cold) so maybe rethink how you clean it. If you still want to wash it while hot, get one of those oldfashioned dishmops. I expect you'd only fit the big grill plates in a laundry trough, so half of it would be sticking out in a kitchen sink. You can touch hot stuff if you wear rubber gloves with cotton gloves underneath. If it's cast iron, the handle will get hot anyway.
  12. looktall
    Sep 17, 2001
    26,733
    try de-glazing the pan while on the heat instead of drenching it in water.
  13. Dogo
    Dogo Member
    Jul 9, 2005
    884
    Melb
  14. Romen
    Romen Member
    Mar 14, 2003
    2,587
    Adelaide, SA
    Hot water is still at least 100c 'colder' than a hot pan...
    I dont see why they dont have such pans though, just have a clip off/on handle for safety etc.
  15. ph3var
    ph3var Member
    Nov 13, 2011
    223
    Western Australia
