Dual switched and dimmered downlights
Discussion in 'Electronics & Electrics' started by Pugs, May 23, 2019.
  1. Pugs
    Pugs Member
    Jan 20, 2008
    9,301
    Highbury, SA
    One for the Sparkies
    Q1: Can you have dual switches and dimmers for the same lights??
    Q2: with bluetooth enabled led fixtures does one still require a light switch??
  2. Symon
    Symon Castigat ridendo mores
    Apr 17, 2002
    4,692
    Brisbane QLD
    Q1. Yes
    Q2. Yes
    Pugs likes this.
  3. Privatteer
    Privatteer Member
    Mar 19, 2006
    862
    Q1. Yes, but basic dimmer's work only at one switch/end. If you use 2 it will never be able to be brightened from other location. The more advanced versions such as C-BUS lighting controls can allow dimming from multiple locations.
    Q2. Depends on the device but in my opinion one should always be installed as an override. Lost remote, flat batteries etc...
  4. Symon
    Apr 17, 2002
    4,692
    Brisbane QLD
    I look at it as a point of isolation, you need to be able to turn off the light to change a lamp. You aren't going to turn off the breaker just to do that.
    Pugs likes this.
