Dumb Question: Is a USB3.0 external drive backwards compatible?
Discussion in 'Storage & Backup' started by dantheman65, Nov 22, 2010.
  1. dantheman65
    dantheman65 Member
    Aug 18, 2001
    3,840
    Melbourne.
    Hi,
    I assume that if I buy a USB3 external drive and plug it in to a legacy port (USB2 or even 1.1) then it will function completely normally sans a loss in speed?
    I just wanted to double check. I assume they'd be insane to make it legacy incompatible.
    Cheers,
    Daniel
  2. R1TeAm
    R1TeAm Member
    Aug 6, 2008
    239
    yeah usb3 drives are backwards compatible so it will just default to whatever speed your ports run at aka 2.0 1.1 or 1
    :D:thumbup:
  3. scheps
    scheps Member
    Jun 25, 2002
    756
    yep..........
  4. doodz
    doodz Member
    Nov 6, 2002
    5,155
    Yes they do....
    But will run at 40MB/s
    If you dont have USB3.0 drivers installed your unit will run at 40MB/s
  5. issa2006
    issa2006 Member
    Feb 4, 2006
    3,234
    AUSTRALIA (ADL)
    not sure about 1.1 but def 2.0 is ok
    dantheman65
    dantheman65 Member
    Aug 18, 2001
    3,840
    Melbourne.
    Brill, cheers lads.
