Easiest way to clean fish tank?
Discussion in 'Pets & Animals' started by nap, Sep 22, 2008.
  1. nap
    nap Member
    Apr 29, 2005
    1,066
    Any tips for the easiest way to clean a fish tank out? (besides the traditional hose/bucket refills)
  2. Urban_Jungle
    Urban_Jungle Member
    Sep 25, 2006
    619
    Thirlmere
    I guess the easiest way is not to have it get dirty in the first place.
    By combining a filter system which filters the water at least 3 times an hour (mine does it 6 times), having enough lower level water movements so that no fish waste can settle so gets picked up by the filter and having cleaning type fish such as bristle nose for algae.
    Other than the above all I do to keep my tank clean is to do a 25% water change each week. Even though every reading in the tank reads 0 I still do this.
  3. tk55
    tk55 Member
    Apr 17, 2008
    254
    wantirna 3152
    great tips! never thought of this one. thanks :)
    nap
    nap Member
    Apr 29, 2005
    1,066
    found pump the easiest
  5. Smoke87
    Smoke87 Member
    Jun 17, 2005
    6,196
    Eh, charging something that was just submerged gives me the heeby jeebies.
  6. The Sentinel
    The Sentinel Member
    Jan 30, 2002
    2,766
    Nuke the site from orbit. It's the only way to be sure
  7. nyah8
    nyah8 Member
    Jan 21, 2007
    347
    Its not that hard to run a siphon hose to the back lawn...:confused:
  8. japes
    japes Member
    Sep 8, 2007
    6,386
    Sunshine Coast
    I siphon out the window with an extension on my gravel-vac, and put the hose in through the window :p
  9. nyah8
    nyah8 Member
    Jan 21, 2007
    347
    Yeah, thats what I thought us normal people did. *stares pointedly at OP* :p :lol:
    nap
    nap Member
    Apr 29, 2005
    1,066
    good point......
  11. tk55
    tk55 Member
    Apr 17, 2008
    254
    wantirna 3152
    i don't know if you're supposed to charge the battery while it's still under water. but it doesn't matter. it's only 12v. won't even tickle a fish :)
  12. eSNAKE
    eSNAKE Member
    57
    You guys crack me up.
  13. japes
    japes Member
    Sep 8, 2007
    6,386
    Sunshine Coast
    Siphon into a sink, and use a faucet attachment to fill the tank.
    nap
    nap Member
    Apr 29, 2005
    1,066
    It's like a cordless drill, there's an internal battery you pull out from a water-tight seal compartment.
  15. Timah
    Timah Member
    Nov 20, 2005
    1,406
    Hurstville
    do you know how good that water is for plants? no way id waste tank water down the sink...
  16. PANZERAMD
    PANZERAMD Member
    Sep 9, 2002
    361
    Bundaberg, Queensland
    I put the water on my plants as well, thought I was the only one that did:lol:
    The Roses in my yard love tank water.
  17. tkdwarrior
    tkdwarrior R.I.P.
    Nov 20, 2006
    360
    I still siphon into buckets to water the plants. Works very well, plants enjoy actually having water + fish ferts help more.
    For cleaning a tank you're breaking down - vinegar on the sponge side of a double sided scouring pad thingo.
  18. Urban_Jungle
    Urban_Jungle Member
    Sep 25, 2006
    619
    Thirlmere
    Always done it. My lemon tree is the main recipient for tank water. It loooves it :).
  19. CordlezToaster
    CordlezToaster Member
    Nov 3, 2006
    4,057
    Tank water taste so much better than green tea! I concur with the plants.
    I use a gravel vac, i don't have no super fancy fishtank pump sucker thingy!
    I 25% water change every week!
  20. PANZERAMD
    PANZERAMD Member
    Sep 9, 2002
    361
    Yeah I use the gravel vacum too!
    I have always done a 75% water change once a month with the oscar tank ( dirty boys ) and a 50% water change with my community tank, I am of the belief that water changes are very stressful for my fish and that less is better ( a stressed fish is more prone disease ). Though if the Silver Dollors have been fighting ( happens a lot ) and they have got wounds on them ( also happens a lot, but does not bother them ) I will do a small ( 25% ) water change and clean the filters.
