EK-XRES 140 REVO D5 RGB - Replace RGB Strip
Discussion in 'Extreme and Water Cooling' started by mctrix, Sep 11, 2021.
  1. mctrix
    mctrix Member
    Apr 1, 2013
    154
    ACT
    Hey all,
    I have an EK-XRES 140 REVO D5 RGB which the colour in the LED strip isn't consistent.
    It seems to have gotten worst over the ~18months of running so i want replace it.
    I have seen a post on Reddit that EK will replace it but in the chance they don't has anyone experienced replacing this strip?
    Once you unscrew the res out of the body of the pump is the strip easy to take out or is it glued?
    https://www.ekwb.com/shop/digital-rgb-led-strip-100mm would this be the replacement part?
  2. juzz86
    juzz86 Member
    Nov 15, 2013
    1,916
    Forth, NW TAS
    Nah, that's a (newer) 3-pin 5V aRGB one mate, from EK's website the 140 REVO uses 4-pin 12V RGB.
    In saying that, if it fits properly all it'll do is convert the res from 12V RGB to 5V aRGB - you just need to make sure you put it in a 3-pin header and not a 4-pin one, or you'll pop it :thumbup:
    Take the RGB strip out and measure the length and width. If it matches the 5V one, you're golden. PCCG have them in-stock locally apparently.
    From the stock photos, it looks a little bit thinner than a bog-standard RGB cable just going on the LED module size - but that may be just photography too.
    mctrix
    mctrix Member
    Apr 1, 2013
    154
    ACT
    Thanks for the reply,
    It looks to come out ok through a slot in the back of the pump. I just need to buy a replacement
    juzz86 likes this.
  4. juzz86
    juzz86 Member
    Nov 15, 2013
    1,916
    Forth, NW TAS
    Awesome. Is it 3-pin or 4-pin?
    mctrix
    mctrix Member
    Apr 1, 2013
    154
    ACT
    4 pin but will do as you suggested and measure for the 3 pin 5v replacement.
    I will drain one of my loops this coming weekend to verify
    juzz86 likes this.
