Embedding an SSID in a web page
Discussion in 'Programming & Software Development' started by Cadbury, May 12, 2014.
  1. Cadbury
    Cadbury Member
    May 4, 2004
    4,781
    Coogee, WA
    Is it possible to code HTML or is there a well known applet which allows a user to click on it and be connected to a specific wireless SSID using an embedded key?
  2. SaTaN
    SaTaN Member
    Jun 18, 2002
    4,790
    Caulfield-ish
    More context is needed for a better answer, but not that I know of. Depending what you want to do you could maybe use WPS pin's to do it
  3. heydonms
    heydonms Member
    Sep 15, 2008
    629
    No, a browser won't allow a website to alter the machine's network configuration and with very good reason. It would be a massive security hole.
    I suppose you might make something using java or a program that the user could download, but it seems like it would be much easier to just provide clear, step by step instructions.
    What problem are you trying to solve?
    Cadbury
    Cadbury Member
    May 4, 2004
    4,781
    Coogee, WA
    Thanks for the reply. I'm trying to send users instructions for how to connect to an SSID whose WPA2 key changes frequently. I was hoping to make it as simple as 'click here', but a set of clear instructions looks like the way to go.
  5. SaTaN
    SaTaN Member
    Jun 18, 2002
    4,790
    Caulfield-ish
    Why does your key change frequently?
    Who are your AP users?
  6. cyclonite
    cyclonite Member
    Mar 7, 2002
    824
    NSW 2009
    I know for Android users you can give them a QR code with the SSID and password to auto-connect. Not sure about desktop OSes.
  7. Foliage
    Foliage Member
    Jan 22, 2002
    32,058
    Sleepwithyourdadelaide
    These are good questions, what is the purpose of changing it regularly? There may be a better solution in which case it makes your original question redundant.
  8. Munity
    Munity Member
    Jan 13, 2006
    363
    you could have them download a executable (or installer) that automatically installs the config to the correct area (or run a batch file that does it)
  9. cvidler
    cvidler Member
    15,592
    Move away from WPA2 PSK to WPA2 Enterprise.
    No shared keys, authentication is done by PKI.
