EMC CX4-120 frequent HDD failure. Why?
Discussion in 'Business & Enterprise Computing' started by Multiplexer, Apr 5, 2013.
  1. Multiplexer
    Multiplexer Member
    Feb 26, 2002
    2,127
    Home
    Anyone know the possible cause for frequent HDD failure? I am not even sure would it be even consider frequent or simply just the norm. But so far we already have 2 HDD replaced in 2013.
    The SAN is a
    * EMC CX4-120
    * 26 HDD
    * 12 LUN
    * 3 Storage group
    * 10 LUN is being used for database server. So very intense read and write
    * Disk is Seagate STE45085 CLAR450
    * About 3 to 4 years old
    My guess is the database intense read and write activities. Any input is appreciated.
  2. Iceman
    Iceman Member
    6,647
    Brisbane (nth), Australia
    Drives are 3-4 years old and SAN's will "fail" out a drive at the first sign of trouble - your data is worth way more than the drive.
  3. Gecko
    Gecko Member
    Jul 3, 2004
    2,715
    I agree with this.
    Another thing to check would be the PSUs, but having 3-4 year old drives is most likely the main problem.
  4. Jai
    Jai Member
    742
    Clearly the 1.3m hours MTBF means nothing :) 148 years between failure... hello consumer please enjoy 0.003% of that!
  5. VR4hore
    VR4hore Member
    Sep 8, 2001
    261
    wellll, maybe not the 'first' sign... but fairly close to it.
    Seems about normal to me anyway.
  6. CordlezToaster
    CordlezToaster Member
    Nov 3, 2006
    4,080
    You clearly have not had the joy of using a dell equallogic ps4000 with sata harddrives.
    As stated that would be expected after 3-4 years.
  7. Myst
    Myst Member
    Feb 26, 2004
    1,350
    Hobart, Tasmania
    Hi fellow CX4-120 administrator!
    We've had about 3 drives fail in the 3 years we've had 2 x CX4-120's. 3 disk shelves all fully populated. I think 2 x Sata and 1 fibre channel have carked it.
    Ours were under warranty though I believe, can't remember how many years they ship with?
  8. gwills
    gwills Member
    Jan 14, 2005
    410
    Id say its pretty normal ,
    I look after a few Netapp systems and find that certain types of drives seem to fail more often than others
    15 K FC Disks I think every one of them has been replaced 14/14
    15 K 144GB SAS None 0/80
    7.2 K 1TB sata probably about 15 / 48
    All in the space of about 4 years.
    Multiplexer
    Multiplexer Member
    Feb 26, 2002
    2,127
    Home
    I suspect the HDD is getting old as well and been hammer by the database just speed up the process and reduce the life span. But how to prove that is that is the case with my manager?
    Also, what is the standard practice for situation like this? Replace all HDD? Hard to communicate that to management $$$.
  10. Iceman
    Iceman Member
    6,647
    You continue to use the SAN and the vendor continues to replace the disks as they fail under your maintenance contract?
  11. obi
    obi Member
    Oct 16, 2004
    127
    You forgot option two: cry into scotch because you were too stingy getting the maintenance contract renewed.
    Multiplexer
    Multiplexer Member
    Feb 26, 2002
    2,127
    Home
    No option two, The SAN is under warranty and we do organise Dell to come out and replace HDD. Was hopping to mitigate HDD failure, because we dont want to go to data center every 2 month.
  13. Renza
    Renza Member
    Dec 1, 2004
    4,929
    you obviously dont know how MTBF works :rolleyes:
  14. aza2001
    aza2001 Member
    Sep 14, 2002
    2,016
    Northmead
    it could be a bunch of things:
    vibrations caused by other devices or the storage itself
    dirty power
    power supplies on the way out
    age of devices
    either purchase extended warranty, extra drives or replace the array
    would also make sure your backups are intact :)
  15. mr.ilford
    mr.ilford Member
    Dec 26, 2007
    101
    At work
    As previously stated by a number of people, this isn't too unusual. As long as you have maintenance and hot spares, no big deal. If you don't have hot spares, why not?
    A previous employer of mine had 3-4 disk failures a week. But we had a lot of disks. Got to know the EMC tech very well
  16. GTiRolla
    GTiRolla Member
    Apr 17, 2007
    361
    Canberra :(
    Only 2 failures is a blessing, I had to replace 8 disks from over the Easter break alone. Usually get 1-2 disks fail a week between EMC/NetApp gear we use.
    Did you see the EMC Advisory regarding certain 15k RPM Drives? - Its last revision we got was after 27th Mar 2013
    Have a look at EMC Advisory ID: emc254763
    Problem: As detailed in the earlier ETA released by EMC, EMC quality management teams have determined that certain 15K RPM, 73GB, 146GB, 300GB, 450GB and 600GB disk drives may experience increased replacement rates.
    Affected customers may experience service events related to core software upgrades and drive replacements.
    You'll need an EMC account to access the advisory (which I'd imagine you'd already have?)
    Multiplexer
    Multiplexer Member
    Feb 26, 2002
    2,127
    Home
  18. GTiRolla
    GTiRolla Member
    Apr 17, 2007
    361
    Canberra :(
    Wrong KB - Try this one :)
