Essence STX need molex power?
Discussion in 'PC Audio' started by Coldplayer, Feb 6, 2017.
  1. Coldplayer
    Coldplayer Member
    May 6, 2008
    1,866
    Carlingford
    Hey guys, i'm looking to get a new soundcard just to fix up my microphone which doesn't work well with my onboard sound and my old soundcard has died.
    I tried a usb soundcard but the quality was pretty shoddy. I found an essence stx online I can purchase for not too much and was wondering do I need to run external power for it to be detected?
    I imagine the external power is for the headphone component of the soundcard which I will not be using. I can’t run external power as I’m running it in a tiny case which is loaded at the moment and doesn’t have extra room for me to run an extra molex cable.
    Cheers
  2. jamieyn
    jamieyn Member
    Aug 31, 2003
    438
    Yep it needs molex power to run unfortunately - if it isn't plugged in, the card wont be detected by the computer :(
    Coldplayer
    Coldplayer Member
    May 6, 2008
    1,866
    Carlingford
    Cheers, just wondering would you of used it and know how good the mic quality on it is?
  4. tree86ers
    tree86ers Member
    Oct 12, 2004
    340
    i would say that would depend on the MIC used.
    what is the MIC that your using for this? i started using a relativly cheap $200 USB mic at the end of last year and it was night and day improvement over the mic's that i had previously used (cost no more that $20 usually)
  5. jamieyn
    jamieyn Member
    Aug 31, 2003
    438
    Sorry - didn't use the mic in the Essence ST (PCI version of the STX)
    What's your use case? I would imagine the requirements for gaming vs recording studio music would be quite different - with different solutions
  6. Silenius
    Silenius Member
    May 25, 2002
    817
    The mic input is fine for gaming but not good for music production.
  7. Cephas
    Cephas Member
    Aug 30, 2002
    364
    I've been using this card for 6 years. (hard to believe)
    Definitely needs Molex power.
    Output is good.
    Never really used the mic.
    Just need it for gaming, and find the webcam mic fit for purpose.
  8. m0n4g3
    m0n4g3 Member
    Aug 5, 2009
    3,654
    Perth, WA
