Ethereum mining rig suggestions
Discussion in 'Blockchain & Cryptocurrency Mining' started by tarkadahl, Nov 10, 2020.
  1. Luke212
    Luke212 Member
    Feb 26, 2003
    10,205
    Never heard of delta 2400 where did you see it?
  2. OCMunkee
    OCMunkee Member
    Jun 28, 2004
    1,698
    Melbourne, VIC
    r3s and 151528 like this.
  3. aussie-revhead
    aussie-revhead Member
    Feb 21, 2005
    19,876
    St Clair 2759
    They output 12.4v, could that be why?
  4. Jaco
    Jaco Member
    Jul 3, 2010
    370
    4114
    Couldn't tell you, I've always used Desktop power supplies as they had resale value
    Luke212 likes this.
  5. Luke212
    Luke212 Member
    Feb 26, 2003
    10,205
    by the way thought it would never happen in AU, but I bought a video card from techbuy and they demanded direct deposit, so i did bpay. They later said NO STOCK, and that they couldnt find my bpay payment. This lasted for weeks. And they wouldnt reply to my 10 emails. So I had to create a bank dispute to pull my money back and suddenly they 'found my payment'. Total crooks. you go read reviews for them, same issue. How can they operate in Australia being like that?
  6. Aussiejuggalo
    Aussiejuggalo Member
    Sep 14, 2010
    3,257
    Sunshine Coast Queensland
    If that's happening to a lot of people then people need to get the ACCC involved, its why the exist in the first place otherwise stores will keep pulling shit like that. A lot of stores have been getting pissy especially with GPUs the last couple of years because of miners and scalpers (although all stores are scalping lol).
    Scorptec for example wont let you buy a GPU with the member pricing enabled, most stores refuse to say stock numbers even when they know them etc.
  7. cvidler
    cvidler Member
    15,305
    (Specs I see says 12.5v)
    that shouldn't be the problem, ATX standard says +/- 5% for 3.3/5/12V rails.
    that's min/max of 11.4/12.6V
    Buuuttt... if it's regulation is poor, running on the high side of the limit already may mean it goes over with transients (rapid changes in load) you'd need an oscilloscope to properly determine that. a multimeter isn't fast enough to track transients.
    Delta is a good reputable brand, so I doubt it's terrible in terms of regulation.
    But again you're flying close to the edge of the standard. and the cards will be made to run at 12v +/- 5%, not 12.5v +/- whatever tolerance the Delta has.
  8. Luke212
    Luke212 Member
    Feb 26, 2003
    10,205
    so why does the delta run at 12.5 anyway? why not 12.0? who did they make these psu for?
  9. Soarer GT
    Soarer GT Member
    Sep 26, 2007
    2,884
    Its cheaper to have less filtering and compensate with higher voltage than to regulate properly (cost of mosfets/heatsinks and caps).
    Why spend an extra $50 per unit to remove ripple and allow fast switching when you can just turn a trimpot and pray?
  10. aussie-revhead
    Feb 21, 2005
    19,876
    St Clair 2759
    If thats all they did that for then thats sad.
  11. Soarer GT
    Soarer GT Member
    Sep 26, 2007
    2,884
    Its a common tactic if you dont have controlled load. Same as if you dont know how long power source to load is (think old school pre PoE analog cameras. As cable length may be over 40m, you need 5.8v to account for losses along the cable so that the end device has 5v.
    Ill give another hint for tuning cards to get max potential out of it. Even if you are using nicehash excavator or gminer, they dont do error checking as good as phoenixminer. So if you think your setup is running perfect with no errors on the console, try running phoenixminer with same overclocks (either with afterburner or octune) and see which card throws an error. Your average hashrate should be equal or higher than what is reported on the console.
    Phoenixminer doesnt seem to perform as good as gminer for me, however their error checking code seems superior. Just another tool to check your setups.
    Luke212 likes this.
  12. Luke212
    Luke212 Member
    Feb 26, 2003
    10,205
    i am almost certain, having gone so far as to write my own gpu ETH miner, that everyones error checking is equal. its EXTREMELY easy to detect errors. thats literally the the whole point of the crypto space.
    its not the error checking, but the gpu kernels will be different on each miner depending how they decided to skin the cat. so you get different core/memory combinations causing different stresses.
    im actually trying to remove the LHR lock now on my miner for education purposes only. nvidia is pretty sneaky i havent worked it out yet.
  13. duck_boy
    duck_boy Member
    Feb 12, 2003
    1,510
    Southern River 6110
    I found Phoenix miner is garbage for 30x0 serier GPUs. Random invalid shares it can go for a day no invalid shared in 2 hours 20 pop up, does not matter what i did still the same. My rigs also suffer from random crash. T-rex on the other hand super stable 20 days straight before I reboot and now it even more energy efficient then before.
    some guy on facebook got his 3080 LHR unlock by accident. He said when he runs 3080lhr it started out at 80mh/s then started to drop to 40 mh/s then the applied the MSI afterburn overclock setting then the GPU stay hash at 80mh/s.
  14. Luke212
    Luke212 Member
    Feb 26, 2003
    10,205
    he probably fixed it for a while and then it drops back down. i think lolminer do this. they keep overclocking it every minute, to get performance roughly 75%.
    i am taking different approach, trying to hide the algo from nvidia.
    OCMunkee likes this.
  15. aussie-revhead
    Feb 21, 2005
    19,876
    St Clair 2759
    Are all models hash rate limited now?
  16. Luke212
    Luke212 Member
    Feb 26, 2003
    10,205
    yep.
    id be careful buying more now though. mining could end before you get a real return.
  17. Aussiejuggalo
    Sep 14, 2010
    3,257
    Yeah apparently the limited ones were the reason for the stock delay, Nvidia changed the silicone to add the limiter (apparently) and you cant be sure which ones are or aren't limited because they aren't saying (again apparently).
    ROI is going to be a bitch, friend has 10k worth of cards and as of a few days ago has only made around 1.7k back after mining for a few months. Doubt he'll see a full return. I probably wont see a return until the end of the year... Providing I'm still mining by then. It's costing me about $2 a day for 3 cards, 1070, 1660 & 6900 at roughly 22 cents per kW (rough math I don't get told how much I'm charged per kW :rolleyes:).
  18. Soarer GT
    Soarer GT Member
    Sep 26, 2007
    2,884
    Yeah I dont use phoenixminer for actual mining. It does wierd shit sometimes like you say. I'm in the gminer camp for dedicated rig.
  19. r3s
    r3s Member
    Feb 9, 2005
    8,116
    logan ( 4133 )
    The box codes tell you what is what.
  20. aussie-revhead
    Feb 21, 2005
    19,876
    St Clair 2759
    Do the limited ones have a different PN? Surely it cant be that easy if they wont say which are limited.
