Ethereum mining rig suggestions
Discussion in 'Blockchain & Cryptocurrency Mining' started by tarkadahl, Nov 10, 2020.
  1. aussie-revhead
    aussie-revhead Member
    Feb 21, 2005
    19,927
    St Clair 2759
    Whattomine says your two GPUs will mine 74 RVN per day vs 0.0019 eth per day. To reach a minimum 0.05 eth payout would take you about 4 weeks to get a return (albeit about aud270), vs $315 in RVN in 4 weeks. Nicehash also reports about $300 earning in 28 days.
    Sorry if you know all that stuff already.
  2. NerfDude
    NerfDude Member
    Jan 26, 2003
    481
    Victoria,Australia
    Current you should use nicehash. You will get regular payouts but can mine different algorithms etc and you only to worry about a single wallet.
    I recommend using trex and not the NiceHash software.
    good video here on setting it up with dual mining
  3. lxboston
    lxboston Member
    Jan 11, 2005
    698
    Bayside, Melbourne
    What MH you getting on your 3070ti’s? Im using coinspot as my wallet with no issues but only get payouts once a month at .2 eth with nanopool.
  4. Luke212
    Luke212 Member
    Feb 26, 2003
    10,224
    Ergo is half as profitable as eth so dual mining ain’t really 100% it’s more like 75%
  5. PiNoY
    PiNoY Member
    Jan 29, 2004
    1,378
    doncaster east, vic
    he can just use ethermine pool and take min payout of 0.005 to the polygon network
  6. Current
    Current Member
    Aug 10, 2021
    257
    Thanks, i am using T-Rex with 2miners pool - asia server for ravencoin and the PC windows Wallet. I can see the transactions every 4 hours which is comforting.
    So when i try eth
    I set things up and i'm not sure if its working because i don't see anything going into the wallet after a long period of time. and i dont want to have it mine for a week burning the electricity and have nothing to show for it ? if that makes sense, i like to know it's working by seeing a result.
    I saw a video where you mine etherium but get paid in bitcoin with t-rex on 2miners ?
    i think this is it
    https://2miners.com/blog/how-to-get-payouts-for-ethereum-mining-without-fees/
    I would like to use less power and not heat up my bedroom as much. I live in a shoebox while im at uni and counting every penny so to speak.
  7. Current
    Current Member
    Aug 10, 2021
    257
    not sure what polygon network is.
  8. Current
    Current Member
    Aug 10, 2021
    257
    So i'm better off staying with raven ? I am paying full electricity price, no solar panels ect:
  9. illdrift
    illdrift Member
    Apr 4, 2008
    289
    PiNoY likes this.
  10. duck_boy
    duck_boy Member
    Feb 12, 2003
    1,575
    Southern River 6110
    You need to take into account that RVN will draw more power, and you need to keep plenty PSU capacity in reserve. Power spike will trip your PSU and shut down your rigs.
  11. Current
    Current Member
    Aug 10, 2021
    257
    850W PSU. Drawing about 440W from the cards, + a bit more for the cpu and rest of the pc. So i think i'm okay for the most part.
  12. Soarer GT
    Soarer GT Member
    Sep 26, 2007
    2,920
    Hey mate. Just a heads up. The LHR cards use a fair chunk of CPU to unlock... in my testing in the workshop, if you hit 100% CPU then you hit a GPU lock on one of the cards.
    So I'm running one of the BTC250C boards Aussie listed before and LHR would always kick in within a minute until it drops to LHR Level 0 or even -1 but my Dell Optiplex 9010 i5's never had an issue. I swapped out the Celeron G3900 to an i5 6500 I had spare on the B250C board and .... whammo. No more LHR kicks. Stays fairly solid at LHR 4.
    I've got generic tune in (+1300 memory) for stability testing but yeah... If you're doing LHR. Get minimum i5. The CPU makes a difference. (Also lucky I have spare CPU's lying around)
    Hope this helps anyone wanting to mine on LHR cards. Needless to say, stay away from all those BTC boards with built in CPU
    Peace Out.
  13. NerfDude
    NerfDude Member
    Jan 26, 2003
    481
    Victoria,Australia
    PM me your full eth bat file and I will help you find it on the pool
  14. r3s
    r3s Member
    Feb 9, 2005
    8,435
    logan ( 4133 )
    Like it has been explained previously, search your ETH address on the pool u are using, this will show u your stats and eaenings, they just dont go to your wallet til u hit minimum payouts......
    P.S , if your after a get rich quick scheme mining isnt for you.
    Soarer GT and PiNoY like this.
  15. FarQ
    FarQ Member
    1,177
    3130 VIC
    Current use a NANO address on 2miners pool.. mine ETH and get paid daily in NANO fee free
    flexpool allows you to lower the payout limit, but then your payout gets hit with a larger percentage of transfer fees eg: 0.1ETH has about 2% t/f fee, 0.01ETH has about 21% t/f fee
    Binance ETH Pool also pays daily into a binance pool wallet address
    ... otherwise you have to hit the minimum payout limit on other pools as already stated
    https://imgur.com/a/YAAs1Ph
  16. Current
    Current Member
    Aug 10, 2021
    257
    looks like a good idea.
    I don't have a nano wallet though.
    this was on the nano website for a wallet
    https://www.exodus.com/download/
    any reccomendations ? i do prefer a desktop wallet or a wallet from coinspot :)
  17. FarQ
    FarQ Member
    1,177
    3130 VIC
    i use binance as my exchange as the buy/sell trades are within a few dollars of each other, unlike others...
    on binance you just select the crypto you want to deposit and generate an address for it.... maybe coinspot is the same?
  18. duck_boy
    duck_boy Member
    Feb 12, 2003
    1,575
    Southern River 6110
    I use Jaxx librety, it used to hold my Zec. Now it hold what ever amount of Bitcoin I have left, bit core need to sync and need heaps of HD space.
  19. Hi-tek
    Hi-tek Member
    Jun 18, 2004
    1,339
    Anyone mine with a H81m mobo? If so, how many GPUs are you running off it?
  20. aussie-revhead
    Feb 21, 2005
    19,927
    St Clair 2759
    Good stuff, how is that board going? How long has it been up? Any hickups?
    I often wonder if a mid range cpu might be better than a low end one, but I guess that can only work if the Celeron or Pentium is struggling.
