Ethereum mining rig suggestions
Discussion in 'Blockchain & Cryptocurrency Mining' started by tarkadahl, Nov 10, 2020.
  1. r3s
    r3s Member
    Feb 9, 2005
    9,069
    logan ( 4133 )
    I was a bit disappointed with the thermal pad performance until i had a light bulb moment.
    The 3080 sea hawk radiator was getting really quite hot and i didnt really see if as a problem as the core was still only 50degrees but saw that because of that the fans were only sitting at 40% , i ramped them up to 100% and the core dropped to 44degrees and mem temps dropped another 8 degrees :D
  2. Soarer GT
    Soarer GT Member
    Sep 26, 2007
    2,964
    I set fan temp trigger when GPU hits 45 :
    This is my 3080ti bat file :
    t-rex.exe -a ethash -o stratum+ssl://eth-au.flexpool.io:5555 -u %WALLET% -p x -w %RIGNAME% --lock-cclock 1410 --mclock 1300 --temperature-limit 75 --temperature-start 60 --fan t:45[85-100] --api-bind-http 0 --lhr-autotune-step-size 0.2 --lhr-tune 74.2
  3. r3s
    r3s Member
    Feb 9, 2005
    9,069
    logan ( 4133 )
    I was used to 3070's and 55-62 degrees was the norm and i never worried about it, so when the sea hawk was running at 45-50 degrees core it was even better, i just didnt realise that the heat soak on the radiator didnt effect the core enough to make the fans ramp up which then made the memory still run hotter then they needed too , i'm happy to run the 120mm fans at 2500rpm instead of 1500-1700 as they arent very loud and i have a shitload of spare 120mm fans if i need to replace them later on and they are a simple 4pin plug to replace each 1 which is nice not making the things some stupid proprietory plug like some manufacturers do....
  4. apemann
    apemann Member
    Jun 4, 2014
    232
    A few weeks until it's announced. Goerli first.
  5. miicah
    miicah Member
    Jun 3, 2010
    7,694
    Mount Cotton, QLD
    So should I keep mining my alt-coin or switch back to eth before the merge?
  6. apemann
    apemann Member
    Jun 4, 2014
    232
    Hashrate has been dropping for a month, expect it to start accelerating its decline as the great sell off begins, rewards might improve a bit in the final run. But its weeks now until D-Day is announced.
    still seems crazy to have been mining at 200k gh/s - never thought it would get to 1m.
  7. r3s
    r3s Member
    Feb 9, 2005
    9,069
    logan ( 4133 )
    Mining ETH til its not minable anymore, is there any altcoins that are more profitable now? Wasnt for a long time.
  8. lonewolf1983
    lonewolf1983 Member
    Jun 12, 2002
    5,060
    Perth, WA
    Depends on the card, my 2080super is more profitable on Flux
  9. sjaeger172004
    sjaeger172004 Member
    Sep 15, 2007
    1,070
    Does this mean no more mining?
  10. apemann
    apemann Member
    Jun 4, 2014
    232
    yep.
    Superphiz, just posted this, which pretty much brings everything together
    https://www.reddit.com/r/ethstaker/comments/tbql1n/five_indicators_that_the_ethereum_merge_will/
    as long as 'the merge' goes alright with Kiln on wednesday or thursday when it swaps over from pow to pos we'd have to expect an announcement about the first merge of an exsiting testnet on or around the next ACD call which is 18th March. once that's annouced... its on.
  11. Luke212
    Luke212 Member
    Feb 26, 2003
    10,277
    What do you mean ‘it’s on’
  12. Jag_Guy
    Jag_Guy Member
    Apr 19, 2006
    563
    Basically it means that everything is tested, and they just set the dates for Ethereum to transition to POS, so the difficulty bomb will likely be set off in June, which means mining will end within a matter of months after that, and once the difficulty bomb is set off profitability will drop considerably.
    Cut a long story short, there is very little stopping Etherum mining ending around June now.
  13. apemann
    apemann Member
    Jun 4, 2014
    232
    If anyone is interested in running validators or staking in a pool
    https://docs.google.com/spreadsheet...RhmmAJ5YtgkvWKWP3OfGCZIYxSA/edit?usp=drivesdk
    Justin drake just released updated projections
    Eth issuance currently around 13500 per day in POW
    It goes to 1640 at the merge.
    The sell pressure reduction from miners is going to be insane..
    There will literally be 12000 eth a day less available + an increase in people staking , currently 28,000 eth a day being added but increases to 35,000 around 28 March.
    In the next couple of months there will be almost 20,000 eth per day less available
  14. havabeer
    havabeer Member
    Dec 12, 2010
    7,347
    Is eth value going to go up or down after the merge, that is big question
  15. Luke212
    Luke212 Member
    Feb 26, 2003
    10,277
    historically they went down on other coins but who knows. eth lt value and crypto in general is dubious imho. hard to sustain without hair brained marketing schemes like nft keeping people interested.
  16. r3s
    r3s Member
    Feb 9, 2005
    9,069
    logan ( 4133 )
    I don't think you understand the projects/businesses that are using the ETH blockchain, and i guess thats why you are a mine to sell type of person rather then holder.
    Luke212 likes this.
  17. havabeer
    havabeer Member
    Dec 12, 2010
    7,347
    You know if you sell you can spend the money on things?
  18. r3s
    r3s Member
    Feb 9, 2005
    9,069
    logan ( 4133 )
    Is that how exchanges work? Knew i was missing something.
  19. Luke212
    Luke212 Member
    Feb 26, 2003
    10,277
    no doubt i dont understand it, but i am dubious because its an actual fad now. so long term value is.... what exactly? how come people expect it to be 1000X USD when other currencies like AUD, GBP dont do that? Why shouldnt ETH be stable at around $1USD like other normal currencies? I mean 1JPY is 0.01x but its always stable ish.
  20. Snoops
    Snoops Member
    Jan 17, 2004
    1,985
    BTC (and to a degree ETH) are best thought to be more of a commodity than a currency when compared to traditional markets. Scarcity is where the value comes from.
