Excel- Easy way to apply same auto to whole table
Discussion in 'General Software' started by xc351, Dec 4, 2018.
  1. xc351
    xc351 Member
    Dec 30, 2005
    2,411
    Pretty much I’m doing up a spread sheet to keep track of costs.
    So every line has the same rules is there a way I can add the same autosum rule to all the coloums even unpopulated ones.
    If it helps I’m trying to work out cost to reload ammo.
  2. Tinian
    Tinian Member
    Jan 3, 2009
    16,546
    15.0° N, 145.63° E
    copy paste?
    xc351
    xc351 Member
    Dec 30, 2005
    2,411
    Yea it’s what doing but every one needs to be adjusted for the rows eg h6*e6 to h7*e7.
    Each row has about 6 formulas
  4. philquad
    philquad Member
    Jan 22, 2004
    920
    nelson bay
    you mean like this ?
    xc351
    xc351 Member
    Dec 30, 2005
    2,411
    I got it sorted. Pretty much a + arrow appears and you can drag it down. Double clicking it didn’t work
    Was just glitchy as anything with my adverage work laptop and a touchpad.
    Plus 1 or 2 issues were in a unassociated table i can put in current powder prices way over on the right. But I can do that manually.
  6. GTR27
    GTR27 Member
    Aug 16, 2002
    8,072
    You can also highlight the last cell that the formula is in, then down to where you want it to go to and press CTRL+D to fill the formula down those cells.
    Double clicking when it shows the '+' only works if there is valid data in the column next to it (so it has some reference as to how far down to fill).
  7. elh9
    elh9 Member
    Feb 28, 2016
    107
    Perth NOR
    Could do something like below VBA.
    Usage:
    1. Place it in the "ThisWorkbook" module.
    2. Set TotalColumn number on 3rd line to numeric value (A=1, B=2, etc)
    Every time you enter a value into a cell the total column will update, whether its a new row or not.
    ** There's probably a more efficient way to do this, but it works
    Code:
    Private Sub Workbook_SheetChange(ByVal Sh As Object, ByVal Target As Range)
    Dim TotalColumn As Integer: TotalColumn = 5
    Dim CurrentRow As Integer
    If Not Target.Column < TotalColumn Then
        GoTo SkipToEnd
    End If
    For CurrentRow = 1 To EndOfRowData
        Dim sumTarget As Range
        Dim result As Integer
        Set sumTarget = ActiveSheet.Range(Cells(CurrentRow, 1), Cells(CurrentRow, (TotalColumn - 1)))
        result = Application.Sum(sumTarget)
        ActiveSheet.Cells(CurrentRow, TotalColumn).Value = result
    Next CurrentRow
    SkipToEnd:
    End Sub
    Function EndOfRowData() As Long
    EndOfRowData = Application.ActiveSheet.Cells.SpecialCells(xlLastCell).Row
    End Function
  8. MUTMAN
    MUTMAN Member
    6,003
    4109
    drag fill is your friend. where you have a cell you want to keep constant in the formula use the "$" sign
    say you are adding three cols in a group of rows;
    A,B, and C and one 'fixed' cell F
    A1+B1+C1+$F$1
    the next line when drag filled becomes
    A2+B2+C2+$F$1
    A3+B3+C3+F$1$
    the $ stops the drag fill from moving that cell down the rows
    hope that makes sense
