Experienced loop builders HELP needed for my first !!
Discussion in 'Extreme and Water Cooling' started by Jody Hodgson, Feb 18, 2019.
  1. juzz86
    juzz86 Member
    Nov 15, 2013
    1,124
    Forth, NW TAS
    I'm the opposite to these guys actually - I don't monitor component temps, just coolant. Just different ways to tackle the same problem. My coolant goes up to 33C in Conan Exiles, I know my shit is working.
    I do it this way because my case has an onboard temp header and display for one channel, and I was sick of running Afterburner in the background for everything (in addition to CAM for the cooling/lights). So I plumbed it into a temp plug and set the CPU_FAN header to monitor pump RPM. Pump drops out - CPU FAN alarm sounds and shuts her down. Coolant doesn't spike while gaming - got an issue along the line somewhere.
    More than one way to skin the cat, pick whatever route you feel most comfortable with - the sagest advice here is definitely to 'keep it simple, stupid' :thumbup:
    mad_mic3 and Jody Hodgson like this.
    Jody Hodgson
    Jody Hodgson Member
    Jan 11, 2019
    28
    So what are you using as a sensor to detect the water temp??
    My mb has pump and temp headers??
  3. radeon_freak
    radeon_freak Member
    Sep 19, 2007
    3,155
    Jody Hodgson likes this.
  4. juzz86
    juzz86 Member
    Nov 15, 2013
    1,124
    Forth, NW TAS
    My case (EVGA DG-87) has a single temp sensor and an LCD readout on the front. It's designed to report a case temp, I just cut the original probe and soldered a 1/4" stop plug with a thermocouple (first link in R_Fs post above) onto it.
    You could achieve the same with a temp header on the motherboard, reporting to whatever software you decide to use.
    Jody Hodgson
    Jody Hodgson Member
    Jan 11, 2019
    28
    Ok all my loop stuff is ordered and I have bitten the bullet on 16mm Acrylic I am going to try some bends and give it a red hot go LOL. THanks for all the help this far and wish me luck I will report back with issues slash successes :)
    radeon_freak and juzz86 like this.
  6. Kaine[zof]
    Kaine[zof] Member
    Mar 22, 2004
    2,179
    Good luck man, holy hell that is a lot of radiator. Sounds like it's gonna be tight, but we don't do this hobby cause it's easy, right? Highly back the tips about monitoring pump RPM on a motherboard header and configuring for alarm & shutdown on fail. Most high end boards should allow you to configure this in bios and possibly run your pump straight off a fan header, I recommend doing this if you can, makes life nice and simple.
    GL, have fun, post pics.
    Jody Hodgson
    Jody Hodgson Member
    Jan 11, 2019
    28
    I have it built just have had to go away with work for a few weeks will post pix etc when I get home
  8. Pazzu
    Pazzu Member
    Jul 16, 2015
    66
    2602 Canberra
    Can't wait to see pics!
    I prefer to use loop temps as I control my fans via the coolant temp. I run my rads passive when cool, and having the fans spin up everytime when the CPU temp spikes just doesn't flow with me.
    It is even more imperative since I'm running dual loops.
    It all boils down to what you are aiming for, my builds are silenced focused. Just my 2 cents
  9. johnyfalco
    johnyfalco Member
    Dec 27, 2004
    43
    Gold Coast, Queensland
    I’m interested to see how this progresses, as I am about to do a similar build with a i9940x, and am about to order all my bits.
    Jody Hodgson
    Jody Hodgson Member
    Jan 11, 2019
    28
    Sorry it’s been a while I have been overseas a fair bit. However it is complete and up and running :) I will attempt to add piccies
    juzz86 likes this.
  11. johnyfalco
    johnyfalco Member
    Dec 27, 2004
    43
    Looks really good. Job well done. How are the CPU temps when running at 100% ???
    But your quoted "MB Gigabyte Auros Master Z390" with a LGA 1151 socket will not fit the quoted "CPU I9-99ook" CPU
    You need a socket 2066 motherboard for that.
  12. Pazzu
    Pazzu Member
    Jul 16, 2015
    66
    2602 Canberra
    Well done, this looks sensational!
    The bends are well excuted.
    9900K is a socket 1155 and works when z390 board?
  13. juzz86
    juzz86 Member
    Nov 15, 2013
    1,124
    Forth, NW TAS
    1151 but you're right - CPU and board are compatible. Blame Intel, there's a 2066 i9 9900X.
  14. johnyfalco
    johnyfalco Member
    Dec 27, 2004
    43
    My apologies, I didn't know there was a socket 1151, i9 9900x, but I did know there is a socket 2066, i9 9900x
  15. juzz86
    juzz86 Member
    Nov 15, 2013
    1,124
    Forth, NW TAS
    Nah you're right mate - the 1151 one is a 9900K :thumbup:
