Family headshots
Discussion in 'The Gallery' started by Spacenoodle, Dec 28, 2013.
  1. Spacenoodle
    Spacenoodle Member
    Jun 20, 2012
    217
    So I tried something different this christmas, as part of my new years resolution to try different types of photography. Tried my hand at some headshots of the family over christmas.
    It went ok for a first attempt, not entirely happy with the results, these are the better ones from the batch, I haven't pulled these in to Lightroom yet, but there is another one or two that I really liked and hope to salvage in LR. I really didn't want to do a white background as these photos are for print and I just hate the way white seamless looks in once printed.
    The setup was 2 reflective umbrellas lighting a bedsheet (yep, ghetto but it seemed to work) either side behind model set at 1/64 power (since the room was absolutely tiny), with a small softbox high camera right at 1/8 power, and a reflector low left.
    These were shot with a 50mm f1.2, and doing so made me wish I had an 85mm. But since I pretty much shoot exclusively video with this camera, I can't justify a 85mm.
    Anyone who has some experience with this tell me how I can get a bit more depth in the light? like more defined jawlines while still having catchlight under the eyes I'd appreciate it. Thanks :)
    Anna by Spacenoodle, on Flickr
    Shin-Ho by Spacenoodle, on Flickr
    Dick by Spacenoodle, on Flickr
  2. dche5390
    dche5390 Member
    Jan 22, 2007
    3,446
    What the hell with the insanely narrow DoF? Why!!?! There's your problem.
  3. stenchlord
    stenchlord Member
    Nov 15, 2006
    5,619
    Sydney, NSW
    Too much bokeh imo. When you've got them posing for you in a controlled setting you should step down a little (f/3.5-f/8 depending on focal range).
    Also not a big issue but WB varies between the shots.
  4. Bashar
    Bashar Member
    Nov 3, 2004
    218
    The shallow DOF is kinda distracting
    Spacenoodle
    Spacenoodle Member
    Jun 20, 2012
    217
    Fair enough, I shot 2 rounds, one at 1.8 and at 5.6. The ones at 5.6 I liked less personally so I didn't post. Guess I should just stick with the others. Thanks for the feedback.
  6. fnp
    fnp Member
    Apr 20, 2004
    2,437
    Wait Awhile
    I don't know anything about photography and can't make any technical comments, but why does Dick look absolutely terrified :lol: Surely there was a better shot than that one?
    Spacenoodle
    Spacenoodle Member
    Jun 20, 2012
    217
    Ah yeah. Lung cancer sadly. He has trouble breathing and was struggling to pose for this one. He didn't want one with the oxygen in so this was the best I got.
  8. Psyentist
    Psyentist Member
    Jan 1, 2010
    411
    Generally it's best to shoot at or below the subject's eye level.
    The neck isn't the most flattering especially in the first one.
    Just add a stronger fill and it should look a lot better
    Spacenoodle
    Spacenoodle Member
    Jun 20, 2012
    217
    Thanks for the tip. Tried but I'm short so next time I'll find something to stand on. First attempted and since I've never done headshots before I kinda had no idea, which is why I posted here :)
  10. vorg
    vorg Member
    Sep 8, 2001
    102
    As well as not having such a tight depth of field , try and use a longer lens , there is too much distortion that makes the noses look large .
  11. stenchlord
    stenchlord Member
    Nov 15, 2006
    5,619
    Sydney, NSW
    A lot of that is likely just standing too close, looks like it was shot with a 50L.
  12. Pinkeh
    Pinkeh Member
    Nov 1, 2008
    11,200
    Shooting too close to subject with the 50mm. You're usually going to get at least half body with the FL at 50mm.
    Shoot from Waist of the person in portrait, and keep your camera level with the horizon i.e. dont be pointing it up/down at the person. If the person is taller than you, jump on a chair :)
    Like the others, the narrow depth is distracting. If you're strobing you should be around f8-f11, so power up the lights.
    Your WB seems to vary between shots. Just set your WB instead of leaving it on AWB
    Not much shadow in your head shots. Shadows define edges. So play with the position and modifiers of your lights. You don't always have to softbox.
  13. cbb1935
    cbb1935 Guest
    Not much more to be said as the posts above have covered most of it.
    For me:
    Standing too close
    Too narrow DoF
    Possibly overlit
    As a test on these shots, look at them normally, then look at them squinting. You'll notice when squinting they come into focus more :)
