Fan power question.
Discussion in 'Electronics & Electrics' started by Builds By Baz, May 14, 2021.
  1. Builds By Baz
    Builds By Baz "Maker of awesome stuff"
    Jun 29, 2009
    3,051
    Builds By Baz
    Jun 29, 2009
    3,051
    Dammit!!! Why can't I get images to post from my android, using imgur as usual?
  3. Symon
    Symon Castigat ridendo mores
    Apr 17, 2002
    4,963
    Brisbane QLD
    It's a shaded pole motor, runs off AC. I would say 240V.
    Builds By Baz likes this.
    Builds By Baz
    Jun 29, 2009
    3,051
    Thanks mate.
  5. MrSquiggle
    MrSquiggle Member
    Apr 12, 2005
    46
    A caution. It is probably mains voltage but it could (unlikely) also be low voltage eg 24v AC if it's small fan. In the absence of testing it's coil impedance you could always rely on a suitably small fuse and stand clear.
    Builds By Baz
    Jun 29, 2009
    3,051
    Thanks guys. I've got some qualified advice now.
    Disclaimer, in all the unqualified electrical projects I have undertaken over the years, I have one self preserving motto. "If you don't understand it, don't touch it."
    Which is why I ask these questions. It helps me decide to either continue with caution, or hand it over to a professional.
    Baz.
    Elmf likes this.
