FEP insulated wire - small qty's ?
Discussion in 'Electronics & Electrics' started by Cererus, Oct 27, 2021.
  1. Cererus
    Cererus Member
    Jan 14, 2002
    1,653
    Hi everybody,
    I'm rebuilding my motorbike engine and specifically need FEP or Teflon insulated wire for the reluctor style ignition pickups which live inside the engine and are exposed to oil up to 150 deg C
    I only need about 2m each of 4 different colours in 18~20 gauge and some oil / heat proof heat shrink, I've got RS and E14 accounts through work and can get the heatshrink but don't need 4 x 50m rolls at high cost.
    There are Chinese Ebay stores that will sell by the meter but the delivery time is crap.
    Anyone recommend Australian sellers who will sell this sort of wire by the meter and any general reliable sellers of sealed auto style connectors like metripack etc. ?
  2. Professor Chaos
    Professor Chaos Member
    Aug 24, 2017
    218
    What if you get a single roll of one colour then use different colour heatshrink at the ends ?
    Still an expensive way to go but trying to find what your after might not be so easy.
    Otherwise I'd try digikey or mouser.
  3. theSeekerr
    theSeekerr Member
    Jan 19, 2010
    3,712
    Broadview SA
    There really aren't any local sources for PTFE or FEP by the metre.
    Buying whole rolls or ordering from China are the only realistic options. The AliExpress store "Ryan's Electric Wire Store" is well regarded amongst hobbyist 3D printer builders for FEP.
    kbekus likes this.
  4. mtma
    mtma Member
    Aug 12, 2009
    5,925
    Cererus
    Cererus Member
    Jan 14, 2002
    1,653
    I would like to thank all for your help, I've ordered thru Gabko.
    Cererus
    Cererus Member
    Jan 14, 2002
    1,653
    FWIW, Gabco took a bit over a week to deliver, so worthwhile if anyone need this sort of wire in small qty's
