First Ryzen Build 1600mhz XMP issues
Discussion in 'Newbie Lounge' started by nope, Aug 28, 2017.
  1. nope
    nope Member
    May 8, 2012
    903
    Got a Asrock AB350 Fatal1ty K4 Mobo with pc3200 1600mhz ram and XMP2.0 wont boot into windows but will load into bios/cmos
    What am I doing wrong? It wants to sit at 1064mhz for no reason and wont upclock even on auto
    Ram slots are a2 b2
    FUCK just checked the QVL its not on there....
    ***kills self***
    seems to be happy at this I can live with 3000
  2. shmity
    shmity Member
    Jun 10, 2005
    914
    You may need to up the ram voltage in the BIOS to get it to post. I had to up mine a bit to get it to boot at 3000.
    nope
    nope Member
    May 8, 2012
    903
    mem at 1.36 seems a bit more stable and dropped CPU to 3.9ghz
    ill keep testing is a 1195 cinebench score good?
    its already at 1.35 how high should I go?
    not adept at memory overclocking at all mate.
  4. shmity
    shmity Member
    Jun 10, 2005
    914
    nope
    nope Member
    May 8, 2012
    903
  6. shmity
    shmity Member
    Jun 10, 2005
    914
    Some boards have more success than others with non QVL ram. I can boot XMP full speed with one of my 16gb sticks but not both. Thats the board not the ram.
    nope
    nope Member
    May 8, 2012
    903
    Seems more stable and ram v1.365 but stock cpu clocks until I figure out exactly whats going on
  8. shmity
    shmity Member
    Jun 10, 2005
    914
    Have you updated the bios? There was a huge number of improvements in the most recent one from AMD and brought a lot better RAM stability with it.
    nope
    nope Member
    May 8, 2012
    903
    yeah 3.0
    seems more stable now ill just keep upping volts slowly
    Should I go to 1.37 or 1.4 and call it a day?
  10. shmity
    shmity Member
    Jun 10, 2005
    914
    I worked all the way up to 1.4 and had no joy, but I didn't try and loosen my timings more along the way. Im pretty happy at 3000 but 3200 would make me happier.
    nope
    nope Member
    May 8, 2012
    903
    yeap its been stable for over 20 hours now ill just up the voltage to 1.37 and call it a day if I get any more trouble
    nope
    nope Member
    May 8, 2012
    903
    Ok well i am having issues again suddenly freezing and cant overclock the ram beyond 2133 without issues no matter what voltage xmp not working at all
    trying latest bios 3.20 and report back
    ok no change still wont go to 3200 or beyond even at 1.5v on the ram
    now at 3066 v1.4 wont even boot into windows without bluescreen at 3200 or above either
    guess ive found the limit :(
    nope
    nope Member
    May 8, 2012
    903
    Still no luck with 3200, anyone else with this mobo have issues with oc on latest bios?
    ram doesnt seem stable under 1.45 fk
  14. zx_spectrum
    zx_spectrum Member
    Oct 13, 2010
    32
    SOC Voltage?
    You will want SOC Voltage at between 1.1v and 1.15v as well as ProcODT=60 Ohms (or might be 53.3 Ohms for your motherboard and ram).
    If it boot loops five times, that is actually a GOOD sign! That is Ryzen CPU training the ram. It should boot after that.
    If no luck with SOC=1.15v, ProcODT=60, DRAM 1.35v then you're basically out of luck.
    nope
    nope Member
    May 8, 2012
    903
    nope
    nope Member
    May 8, 2012
    903
    RMAing this ram hopefully solves hte problem otherwise new board time
