Formd T1 ITX Water-cooling Adventures
Discussion in 'PC Build Logs' started by AdamMB23, Sep 29, 2020.
Should i sleeve my custom 24-pin cable?
Poll closed Dec 3, 2020.
  1. Black sleeve
    6 vote(s)
    85.7%
  2. Unsleeved
    0 vote(s)
    0.0%
  3. Who cares
    1 vote(s)
    14.3%
  1. Yuddy
    Yuddy Member
    Dec 24, 2013
    20
    Very nice and clean build mate. Ordered my T1 as well so looking into pump / res options. I have a aorus 2080ti with EK waterblock but it is much longer and taller than FE cards and blocks. Do you mind if I get some clearance measurements from you?
    How'd you go fitting the DDC pump and magic-cube?
    AdamMB23
    AdamMB23 Member
    Dec 3, 2017
    174
    Thanks! Feel free to send me a pm with any clearance concerns (dont want to clutter the log). Ill do my best to help :)
    Had to put my build on pause for a bit due to uni exams - but the ddc should be in my sunday so will let you all know!
    Yuddy likes this.
    AdamMB23
    AdamMB23 Member
    Dec 3, 2017
    174
    So i sleeved the 24 pin. I think it turned out alright. There are a few ones that are not quite the right size. It powered on an old system without exploding so thats a positive. But its far too bulky, the sleeving makes it very difficult to fit the tube comfortably across the front and the tension in the cable is making me uneasy...
    I will be making a non-sleeved one soon and seeing how that fits.
    20201124_191800.jpg 20201124_191810.jpg 20201124_192336.jpg 20201124_192346.jpg 20201124_192414.jpg 20201124_192632.jpg 20201124_192700.jpg
    passwordistaco, SSJ4, Tazor and 2 others like this.
  4. h2oxide
    h2oxide Member
    Dec 9, 2009
    3,866
    Looking clean
    AdamMB23 likes this.
  5. evade
    evade Member
    Jun 6, 2003
    254
    Neat job with the cables man, I found the same thing - It took FOREVER to make, and then was just bulky and not flexible at all..so I ended up not using it..Lesson learnt!
    Coming along well
    AdamMB23
    AdamMB23 Member
    Dec 3, 2017
    174
    Bye bye bulky, rigid cables. Hello sleek, flexible and super easy to make unsleeved cables. I am way happier with how the unsleeved cables turned out - sizes are more accurate, easily malleable and pretty subtle in my opinion. Bonus - less burnt fingertips. Also managed to fit in my DDC pump - EK 3.2 PWM with MagicCube. Any ideas on what to do with these ugly molex/3-pin?
    Also - stupidly tried to remove my GPU without undoing the white-plastic clip on the riser and it snapped. Anyone know where to source another one of these clips??
    20201202_212200.jpg 20201202_211030.jpg 20201202_211034.jpg 20201202_212140.jpg
    h2oxide, evade and Yuddy like this.
  7. evade
    evade Member
    Jun 6, 2003
    254
    You can rewire the molex into the 4pin fan connector..as long as your mobo header can pump out enough juice.
    AdamMB23
    AdamMB23 Member
    Dec 3, 2017
    174
    Great idea - have absolutely no idea how to do that but i am sure reddit has some useful information. Cheers
    edit: quick google, x570i strix only puts on 1A/12W per fan header. Reddit says 2A/24W is typically needed. Bit of a buzz kill
  9. SSJ4
    SSJ4 Member
    May 16, 2017
    1,133
    Did you shorten your stock cables or make them from scratch?
    I need to make my custom cables and would love to keep them sleeved haha
  10. irR4tiOn4L
    irR4tiOn4L Member
    Nov 25, 2004
    3,082
    Carlingford, Sydney
    Looks great! How are the temps? Have you considered a 2 x 240mm rad build?
    AdamMB23
    AdamMB23 Member
    Dec 3, 2017
    174
    Made my own. They cables are 16awg for single, and 18awg for double wires crimped to 16awg female terminals. Sleeving is definitely possible, but it is more feasible in a soft-line build. Id also look for more malleable sleeving, maybe paracord? Not sure - but definitely doable and not as difficult as its made out to be. Shortening stock cables is also a good idea, save a lot of effort.
    Yet to really get this going! Briefly had it running with a DCLT setup but pump noise was annoying so trying ddc. I have considered 2x240, even have all the equipment for it, but really dont want to swap out my magnitude block for the aquanaut. Maybe if i got a 3080. But in saying, 120 rad is on the cards and fits nicely...
    AdamMB23
    AdamMB23 Member
    Dec 3, 2017
    174
    Another update: After a brief interlude, I finally managed to get it to a workable state. Here is an abridged version of my recent efforts:
    - Sleeving of the EK 3.2 PWM molex / 4-pin cable. Unfortunately my motherboard (Strix x470i) does not pump out enough juice from the fan headers to run the DDC off the fan header alone. This means I had to create adjust a molex cable off another PSU, and re-pin the other end to fit a 6-pin. Also means that i have a lot of extra cables (30-40cm) worth that i have had to tuck above the pump. Its not the prettiest, but its the most practical solution currently.
    - Installation of the DDC pump means I had to re-route my DDC to GPU Run. The height off-set between the DDC and GPU made for an unattractive angle. My solution was to slightly angle a few rotary 90 fittings coming off the GPU block until it was straight with the DDC pump. Shown below in photos.
    - Saw a reddit post about NF-A12x25 fans being feasible with the TX240. So I went out to centrecom, bought two functional but ugly af poo-brown NF-A12x25 fans and began sanding away. Strange thing to immediately do to $150 worth of fans, but was too impatient for the second hand market. Sanded around 3-4mm off the intake side, and around <1mm off the exhaust side. Also removed the radiator mounting equipment, netting me another 1mm clearance. The fans now sit at around 21mm, in a 20mm space. This leaves a minute buldge that is easier felt than observed. These fans are near silent up to 1300-1500rpm, which makes them more preferable to the NF-A12x15 Chromax that i originally installed. Temps are comparable, but overall, I prefer the NF-A12x25. More in-depth testing to come when i have finished moving houses.
    - Had to re-do the CPU to RAD run, as the DDC pump means the Tx240 has to be tucked right up against the edge in order to fit.
    - Ordered an EK-Classic backplate to fit on to my 2080ti. Vector backplate overhangs by around 3-4mm, occupying too much space for the DDC pump to fit.
    - Managed to break my DC-LT2600 pump without ever using it! Just goes to show how great alphacool products truly are (2 eisstations down, 2 pumps down = never touching alphacool again. Same basket as Gigashit for GPUs).
    - Bleeding the loop is a pain, recommend using a large reservoir and letting it run for awhile. Also recommend using a soft tube with ball-valve coming off an extender so you can rotate the case easier without spilling water out of the reservoir (unless you have a lid).
    - Also recommend not forgetting to fit the temp sensor into the loop.
    BASIC Temps: (5600x @ stock, 2080ti undervolted to .950mV for ~2055 Mhz, Side + top panels ON, Pump locked to 1300rpm, Fan around 1300-1500 rpm. Ambient 25c+)
    - After a few hours of Warzone, Cyberpunk, 3D mark and Heaven, the CPU settled at around:
    - 2x NFA-12x15 = CPU 70, GPU 55-60.
    - 2x NFA-12x25 = CPU 65, GPU 55-60.
    Things to do:
    - Add in the white texture fluid from EK.
    - Add in Temperature Sensor
    - Figure out if the GPU is just coil-whining, weird buzzing sound under GPU load.
    - Try and fit in a TX120 infront of the GPU.
    Sorry about the photos, im not a photographer and its very dark in my house. My s10 is struggling.
    MoneyShot 1.jpg MoneyShot 2.jpg MoneyShot 3.jpg MoneyShot 4.jpg MoneyShot 5.jpg MoneyShot 6.jpg MoneyShot 7 (2).jpg MoneyShot 8.jpg MoneyShot 9.jpg
    Yuddy likes this.
  13. Yuddy
    Yuddy Member
    Dec 24, 2013
    20
    Very nice mate. I ended cancelling my T1 order as they have troubles with aluminium suppliers and said a V2 is coming shortly with support for longer and taller GPUs . So I guess I'll have to wait til then.
    But loving your work mate.
  14. passwordistaco
    passwordistaco Member
    Jun 11, 2013
    99
    This looks incredible. Awesome build mate! Following for more progress updates.
    AdamMB23
    AdamMB23 Member
    Dec 3, 2017
    174
    That is unfortunate - sounds like they really ran into a brick wall. Hopefully T1 V.2 is worth the wait though - the adjustable bracket sounds quite attractive.
    Cheers mate! Keen to try and fit another rad in there somehow!
    AdamMB23
    AdamMB23 Member
    Dec 3, 2017
    174
    Want the power of Noctua NF-A12x25 but not the poo brown colour? Fear no more - introducing my not-so Chromax NF-A12x25s with their sleek poorly spray painted design.
    AdamMB23
    AdamMB23 Member
    Dec 3, 2017
    174
    So last night my GPU started hitting 90c, my CPU 88c. A very quick trouble shoot and it appears my pump has died. Ek 3.2 pwm only lasting 3 months on ek cryofuel. Very dissapointed. Now to start the warranty process whilst my T1 idles...
  18. Yuddy
    Yuddy Member
    Dec 24, 2013
    20
    Wow that's short.. hope mines not the same
  19. evade
    evade Member
    Jun 6, 2003
    254
    That sucks, what speed were you running at? I’ve heard they overheat and can die..
    AdamMB23
    AdamMB23 Member
    Dec 3, 2017
    174
    It was running at ~ 1500rpm i believe. Coolant temp was 23 above ambient at around 46 when i last measured it properly. Not really sure why it died but not overly impressed.
    SSJ4 likes this.
