Fridge cooling (56k warning lots o pics)
Discussion in 'Extreme and Water Cooling' started by PHATE-ALITY, Jan 16, 2004.
  1. Long Haired Git
    Long Haired Git Member
    Jul 26, 2001
    2,667
    Hornsby, Sydney
    If you place it in reservoir, then make sure flow from PC is aimed to hit and flow over it, and get the inlet back to the PC as far away as possible....
    PHATE-ALITY
    PHATE-ALITY Member
    78
    WOLLONGONG
    yeah im going out tommorow to buy a chunky arse res, im looking for something over 10L if its possible, see how it goes. But for now im back to stock speeds and noise fans :(
    PHATE
    PHATE-ALITY
    PHATE-ALITY Member
    78
    WOLLONGONG
    Well to update my progress, i broke my fridge when i was making the res. Im pretty sure i borked the thermostat. So i shelved the fridge project. But today i just scored a new fridge which is identical to my other one so over the next few weeks im going to be tinkering about with it and ill be back to water again at some point.
    ill chuck some photos up at some point
    PHATE
  4. Silver_Platinum
    Silver_Platinum Member
    Apr 1, 2004
    1,321
    Mt.Waverley(Vic)
    Why don't you bypass the thermostat, and run the compressor continuously?
    -SP
    PHATE-ALITY
    PHATE-ALITY Member
    78
    WOLLONGONG
    Well i was under the impression that fridge compressors cycle on and off because they are not meant to run contiuosly. Perhaps im wrong.
    PHATE
  6. Silver_Platinum
    Apr 1, 2004
    1,321
    Mt.Waverley(Vic)
    Any compressor can run 24/7, I know Mred32 has managed to and that is what I'm planning to do, a fan on the compressor would be beneficial but I doubt if it is highly necessary. Did your temps vary significantly whilst the compressor was "off"?
    -SP
    PHATE-ALITY
    PHATE-ALITY Member
    78
    WOLLONGONG
    Well that fridge is gone now cos im not confident that i can wire it for continouse use.
    When i had the fridge in its original setup(see pics above) my temps slowly rose whilst the computer was on, so im assuming that in that form it wasnt cooling very efficently so im not really sure how much the temp was affected by the cycling of the compressor.
    Im pretty confident that long haired gits suggestions would have improved my temps alot, but i never got to try.
    But when i get around to fixing my new fridge ill update with more pics and temps.
    PHATE
  8. Mjollnir
    Mjollnir Member
    6,312
    Melbourne, VIC3104
    stuff fridges, aircon are prob better suited to the task.. easily to mod to
  9. chugga15
    chugga15 Member
    May 10, 2003
    504
    north shore, sydney
    for christs sake, make sure you put some beer in the fridge this time. :weirdo:
  10. javascripterror
    javascripterror Member
    Mar 8, 2002
    3,169
    NSW
    Good idea to change the name from water cooling to beer cooling chugga15.
  11. chugga15
    chugga15 Member
    May 10, 2003
    504
    north shore, sydney
    how long do you reckon beer would last in a W/C rig? i know vodka has been done...maybe i should analyse multiple beers and see which has the best performance.
    i have my money on the carlton draught that i have on fridays nights at 5:01PM. best brew ever....mind you metho would taste good then too....
  12. javascripterror
    Mar 8, 2002
    3,169
    NSW
    For our Tasmania membership I think BOAGS would be to viscous and clog up the pump head.
