FTTC Home network gear advice
Discussion in 'Networking, Telephony & Internet' started by samboy, Feb 23, 2020.
  1. samboy
    samboy Member
    Jun 24, 2012
    43
    Hi OCAU'ers
    The supposed great NBN is in my area, we currently have Coax at home and I'm looking to upgrade my network and internet.
    Looking at the 100/20 plans and since its FTTC I think it were getting is xDSL via copper, I believe this should go through an NBN NTU then ethernet.
    I was looking at redoing the home network with Ubiquiti gear, including an edge router, and 2/3 AP's
    We have at least 8 people using the internet at a time, so getting the wifi right would be good.
    Trying to spend as little as possible while getting control of the network with the following equipment
    Ubiquiti Networks EdgeRouter ER-X-SFP 6 Port PoE Gigabit Ethernet Router $125
    X2/3 - Ubiquiti Networks UAP-AC-LITE Dual-Radio Wireless 802.11AC Access Point $139 EA
    Open to suggestions any better ways to do this?
  2. willus
    willus Member
    May 12, 2014
    31
    If you've already got coax now, are you sure it's FFTC that's coming? Either way, it'll come out of the NBN box as ethernet.
    Not sure how big your home is but if there's 8 people in it I'm assuming 5ish bedrooms
    There's no better way to do good home networking than what you've linked. I use and EdgeRouterX in my small house with a single old model LR unifi WAP sitting in the ceiling (which is not in spec btw) and it's been 100% rock solid
    If it's brick internal walls, you may need 3 waps, if it's 2 storeys (and not concrete), 2 is fine. If you need wifi in the backyard I'd get at least one LR wap to cover that. Luckily you can just add more later if you need better coverage
  3. connico
    connico Member
    Jan 30, 2004
    3,766
    8 on a single AP will depend on how much bandwidth each use consumes. Will some of those 8 be on wire at all?
    samboy
    samboy Member
    Jun 24, 2012
    43
    Mostly Wi-Fi I think only I will be on the network
  5. connico
    connico Member
    Jan 30, 2004
    3,766
    The equipment you listed is fine. I do recommend that you cable the APs to the router so you don't 1/2 your wifi bandwidth connecting the AP via wifi. Otherwise your equipment selection is fine
