GA-MA790FX-DQ6 thoughts and problems
Discussion in 'AMD x86 CPUs and chipsets' started by WarezNimph, May 17, 2008.
  1. WarezNimph
    WarezNimph Member
    Feb 21, 2002
    145
    Merimbula NSW
    hi all
    just sold my M2Nsli-deluxe and grabbed the GA-MA790FX-DQ6.
    So far all looks good except for the bios options...
    It uses the ati SB600 chipset for sata and also had GB sata ports which share the external 2 x ESAta ports located on M/B.
    Problem is whenever a ESATA hdd is connected, either machine will not go past post in bios. Once windows is loaded ,i plug in the esata drive and vista freezes until i remove the drive again.
    THe ports are setup in the bios, but not sure what else to do..
    any thoughts, as im using the external drives with USB ATM until i can sort out the esata
  2. Sniper
    Sniper Member
    Jun 26, 2001
    3,686
    Mid North SA
    the GB chipset drivers are installed, I take it.
    WarezNimph
    WarezNimph Member
    Feb 21, 2002
    145
    Merimbula NSW
    yeah drivers are installed..
    even at post, when a esata drive is connected, machine will not go past post unless i remove esata drive
    drives work fine on other pc
  4. BuzzPuppy
    BuzzPuppy Member
    Apr 22, 2004
    2,636
    SE 'Burbs, Melbourne VIC
    Version of the BIOS on the motherboard?
  5. Punk
    Punk Member
    Mar 15, 2002
    1,058
    Walking on Sunshine
    try updating your bios
  6. chicken-
    chicken- Member
    May 2, 2005
    664
    Fortitude Valley, QLD
    My DS5 (DQ6 w/only 2xpcie16) has the same problem. To get around it, I need to connect the esata drive in these exact steps:
    1. PC off
    2. Esata drive off and unplugged
    3. Connect esata cables
    4. Connect esata drive power and turn on
    5. Turn on PC
    also if you haven't flashed a new bios as suggested, you really should... the Gigabyte 790FX boards are excellent, but they are really flaky when running early (F1-F3 or so) bios versions with the latest F5 release they are solid.
    WarezNimph
    WarezNimph Member
    Feb 21, 2002
    145
    Merimbula NSW
    running latest bios
    restored defaults as per bios upgrade
  8. MotoMan
    MotoMan Member
    Dec 24, 2001
    2,776
    Vic Rural
    try plugging the drive into the esata port without the external case..
    perhpas your motherboard isnt compatible with the external boxes chipset
  9. stablez
    stablez Member
    Apr 8, 2006
    4,038
    Humidycrib
    Represent DQ6 lol. good to see some AMD dedicators. My first build was an opteron 180 and it was the 170/165 i should of bought.:leet:
    WarezNimph
    WarezNimph Member
    Feb 21, 2002
    145
    Merimbula NSW
    ok...will give i a go
