Gaming cabinet / arcade machine
Discussion in 'Modding Worklogs' started by Furious, Sep 9, 2014.
  1. OP
    Furious
    Furious Member
    Apr 28, 2005
    380
    Melbourne, Australia
    It's easy enough to just use a multimeter to work out which is which.
    Plus, if I've done my job properly, there shouldn't be any trouble shooting! Famous last words! hahah
  2. INerTIal
    INerTIal Das Uber LemMinG
    May 1, 2003
    896
    Perthican
    Also wires that are installed inside something like this tend not to fail spontaneously.
    Furious
    Furious Member
    Apr 28, 2005
    380
    Dummy fit of screen. It's a Samsung 6300 60".
    Seems it is thicker at the bottom than the top, so it's slightly angled facing up.
    I will machine up some 16mm thick round spacers in either nylon or aluminum (whatever I have laying around, but nylon preferably) to space it off the cabinet face. This will make it level and also give me a space to run the power and HDMI cable.
  4. d33g33
    d33g33 Member
    Dec 28, 2012
    180
    I really love this build. The size of it, it's styling. Amazing. Obviously this isn't your first one but i think it's awesome. Keen for more updates!
    Furious
    Furious Member
    Apr 28, 2005
    380
    Thanks! But, yes it's my first build - never done anything like this before.
  6. MyDixiesNormous
    MyDixiesNormous Member
    Jan 21, 2003
    2,419
    Melb
    Love watching your build. after 10 years of wanting to build a cab im finally gong to do it this time. As you go through the build could you list everything that you put into the cab? Like the button encoder etc etc. What are you planning to d hardware wise? Running a pc? What are you planning to do about sending the video signal to the monitor? Scan line generator?
    Where abouts are you getting your hardware from (buttons, sticks etc)?
    Im still new to this so im not up with the lingo or if certain aspects of cabs are still relevant as the hardware has changed after 10 years.
    Thanks
    Furious
    Furious Member
    Apr 28, 2005
    380
    Thanks!
    I didn't mention where I got the joysticks, buttons and encoder from becuase I was pretty disgusted with their service. Since you asked it was "Game Dude" in Queensland - but I wouldn't recommend them, whilst I eventually got what I wanted, it was a very poor experience.
    The encoder I am using is a i-Pac4.
    Yes, will be running a mid-range PC, probably an old one I have laying around as the processing power required is not very high.
    No hardware scan line generator planned as yet, most of the emulators do software generated which i'll probably use.
  8. d33g33
    d33g33 Member
    Dec 28, 2012
    180
    Awesome. On another note I recently used Power to Make for a replica R2-D2 I'm building and they were very easy to work with and contacted me to check and confirm anything they weren't 100% clear on. Great service.
    Furious
    Furious Member
    Apr 28, 2005
    380
    Had the joystick mount laser cut from 3mm stainless, and I counter sunk the holes.
    Pulled the joystick apart:
    Then assembled it back together with the plate sandwiched between the joystick top plate and base.
    Furious
    Furious Member
    Apr 28, 2005
    380
    In order to space the joystick top plate from the mounting plate, I need to make some spacers that are exactly 2.38mm thick. That way it would be supported everywhere and provide the most rigid mounting.
    I made the spacers from some 25mm wide, 3mm thick mild steel bar. I milled them to shape, and then ground them on a surface grinder down to the eaxct thickness.
    On the surface grinder:
    Finished spacers:
    Spacers bolted in place:
    And finally, the whole thing screwed into the underside of the control panel.
    Furious
    Furious Member
    Apr 28, 2005
    380
    Haven't done much recently, but got the wiring the to the subwoofer all tidied up.
  12. d33g33
    d33g33 Member
    Dec 28, 2012
    180
    How you going with this?
    I'm about to have a good crack at nailing some Arcade machines starting with R2-D2. keen to see how your project is progressing?
