General Aquarium Talk NO SELLING Swaps go in the Fish/Plant Swap Sticky
Discussion in 'Pets & Animals' started by Zoiks, May 9, 2008.
  1. bYrd
    bYrd Member
    Sep 14, 2001
    2,328
    NE Melbourne
    Oh that is delightful, perfect set up (and it appears your other half approves!); props to your work and finishing details.
    I’m looking into getting a nano tank for my study; can anyone comment on long term use of the Fluval Edge 23/46L and/or Biorb setups? Yes I know I’m paying dearly here for aesthetics over function, both are tricky to clean and I’ll be very selective on fish.
    n3wbi379 likes this.
  2. n3wbi379
    n3wbi379 Member
    May 15, 2006
    4,633
    Melb
    I did do it once, it didnt like to be honest.
    Whites gives it that timeless classic look.
    MUTMAN likes this.
  3. MUTMAN
    MUTMAN Member
    9,955
    4109
    just shit stirring :)
    the black didnt look like i thought it would either :(
    the white is great :thumbup::thumbup:
  4. n3wbi379
    n3wbi379 Member
    May 15, 2006
    4,633
    Melb
    I cant believe your still floating around on OCAU.
    Ive been missing for about 8 years lol
    MUTMAN likes this.
  5. MUTMAN
    MUTMAN Member
    9,955
    4109
    welcome back :)
    im more surprised Agg has put up with me for all this time :)
  6. Johnbu
    Johnbu Member
    Jul 14, 2005
    3,279
    SE Melbourne
    Looks great.
    Hate to see your electricity bill heating up 1000L of water in the garage :D
    One thing I am concerned about is the structure the wall/house.
    The weight of whole length of the blue section of wall is supported by the red single studs.
    Should be at least double or triple studs under the lintel. I'd say the wall is load bearing because I can see there are 2 double studs which have been cut.
  7. n3wbi379
    n3wbi379 Member
    May 15, 2006
    4,633
    Melb
    This is the old setup... been running for 10 years since the house was built.
    The wall is NOT loading bearing... would have collapsed by now lol.
    You check these things before you build or pull wall down.
    MUTMAN likes this.
  8. Johnbu
    Johnbu Member
    Jul 14, 2005
    3,279
    SE Melbourne
    Fair enough.. you'll be surprised how many dodgy renovations occur where they simply cut the load bearing studs, which is only discovered much later on when the plaster starts cracking.
  9. Digit
    Digit Member
    May 30, 2009
    1,849
    Hehe, so I grabbed another tank, already set up with a pair of Apistogramma panduro. It's been set up here for about a week and they've already spawned!! Some amazing plants in there too!
    Daft_Munt, Agg and MUTMAN like this.
  10. MUTMAN
    MUTMAN Member
    9,955
    4109
    looks like you have a case of MTS
    if you get advice now you can stop it before it takes over
  11. Digit
    Digit Member
    May 30, 2009
    1,849
    I do... badly! Haha.
    I've got plans for more too lol haha, a few display tanks in the house (1 saltwater reef, 3 freshwater) and a rack for breeding to hopefully cover running costs. Haven't started yet though, still in the planning stage.
    fredhoon likes this.
  12. jonsey
    jonsey Member
    Jun 27, 2002
    157
    I have a bad case of Multiple Tank Syndrome (MTS) I used to keep a fishroom, however, I moved interstate and took 12 month contracts in multiple states so I was fish tank free.
    I moved back to QLD but due to covid I wasn't able to move into my townhouse and instead renting. It has a 2nd living room, it now has a 4ft planted high tech tank, 3 tier african 4ft rack 4ft sump with partition for a 2ft tank, a 4ft and 2x 2ft all plumbed, and a 6ft rack, 2x 6ft tanks with sump. I have done the measurements for another 6ft rack but I am doing my best not to do it until I can move into my place as moving it will suck.
    fredhoon, Digit and MUTMAN like this.
  13. Digit
    Digit Member
    May 30, 2009
    1,849
    Haha that's awesome, got any pics? I'm interested to see what you're using as racking for 2 x 6ft tanks
  14. fleetfeather
    fleetfeather Member
    Oct 24, 2013
    734
    Progress on the Peninsula 15 Mini. The hardscape isn't perfect, but it's close to what I'm looking for. Plants will be mostly Anub, Ferns, Mosses, and Buce's, plus a carpet :)
  15. fleetfeather
    fleetfeather Member
    Oct 24, 2013
    734
    A quick question for the group as I prepare the above tank for planting:
    If i buy a bunch of submersed-grown monte carlo, how should I go about planting it without it rising to the surface during flooding? It should have a root structure to it, but I forsee it still rising up if I plant it directly into soil (but could be wrong here)
  16. Digit
    Digit Member
    May 30, 2009
    1,849
    I can't say I've tried it but I assume if you plant deep enough it should be fine, if not you can weight it down with little plant weights you can buy, or maybe a breadclip will work?
    Hopefully someone can help you out further though
  17. .Radiant
    .Radiant Member
    Nov 25, 2009
    5,272
    4113
    Monte carlo is really tricky to be honest, it doesn't have a deep reaching root structure to begin with and uproots easily even when established. If you're getting a decent mat of it, I'd break it up into small clumps and plant the clumps deeply. Cross your finger it takes hold and good luck if you have any critters that root around.
  18. Technics
    Technics Member
    Apr 29, 2002
    2,088
    Brisbane, AU
    I agree with the planting deep part. Even if you mostly bury it it will still grow up and out. I break it up into small clumps and use tweezers and plant into well moistened substrate. It also helps to use a fairly fine substrate. I still have bags of ADA Amazonia powder I use for it but anything fine should work.
  19. fleetfeather
    fleetfeather Member
    Oct 24, 2013
    734
    Gotcha. Thanks all. I get the strong feeling this is going to be one of the more frustrating (and expensive) elements, but hopefully it's worth it
  20. Daft_Munt
    Daft_Munt Member
    Jan 23, 2003
    7,601
    Hobart, The Federal Group
    I hate you, for getting me interested in that tank... My 3x2x2 is in storage, along with the filters, heater and gravel. I dont think the undergravel heater will last...
    Digit, like the apistos, looks like the prefect tank for breeding
    fleetfeather likes this.
