Gigabyte HD 4890 Fan Noise (solved)
Discussion in 'Video Cards & Monitors' started by MrTanman, May 12, 2009.
  1. MrTanman
    MrTanman (Taking a Break)
    Nov 9, 2008
    100
    So I bought a 4890 the other day and installed it and when it is on, the fan makes this rattling/ vibrating/ shaking noise. Is this normal?
    Also, I don't know if this is normal but when I it is on around 85% load (Far cry 2 benchmark test), the fan speed is around 1500rpm (26%). And when idle, fan is at around 1050rpm (22%).
  2. HPTECH
    HPTECH Member
    Jan 9, 2002
    287
    Vic
    Doesnt sound normal.. Mine is loud, but no rattling..
    As for fan speed, if left on auto. its not overly audible.
  3. dsquad
    dsquad Member
    Apr 27, 2006
    895
    I had to RMA a 4890 for a 'rattly' noise. Turns out it was the wire inside the fan touching a moving part on the inside.
    'Wiggling' the exposed bit of power cable for the fan could make it worse/better, but it would come back.
  4. runkett
    runkett Member
    Oct 8, 2007
    608
    Seems I may have a dud 4890 card with this same issue - So I would be correct to assume this is ment to be no rattle noise and only an air moving noise from the card right? At some fan speeds mine sounds like a chain saw...
    Yay for another RMA fight- glad I didnt sell the old card yet
