Going green. Starting with my computing
Discussion in 'Electronics & Electrics' started by Yoodaa, Jul 12, 2010.
  1. Yoodaa
    Yoodaa Member
    Sep 25, 2003
    1,668
    Ok so going green is something that I have wanted to do for a long time, but due to cost restraints, or not owning a property, it has made things difficult.
    I plan to install a household solar system hopefully next year. Yeah I know it costs a lot, but I have a fairly well paying job, and by looking at it as an investment in the future, and environment, it makes the choice so much easier. At this stage I am unsure If I should go grid/offgrid. If going grid, I want to make sure I generate more than I use as I am not interested in paying power bills.
    So I am coming to the electronics gurus of OCAU to help me take a bite into the solar world.
    I have done some tests with a power meter I bought from Jaycar. I found the following results when measuring computing devices.
    I have a desktop PC with 4 screens, speakers, etc, It pulls about 200 watts on average.
    I just bought a new Toshiba T130 ultra low voltage laptop which pulls only 25 watts when charging, and 15 watts when it if fully charged! That's a huge difference! My ADSL modem pulls 7 watts.
    So I was going to sell the desktop machine, and use that to fund my green solution. This is a small project to get me familiar with how solar works, and the technologies involved.
    I was wondering if someone can help me calculate what size panel and battery/batteries I would need to sustain my new laptop and modem. Again I understand this is not a conclusive solution to my overall solar needs, but I am hoping to merge this system with the big system I plan to install down the track.
  2. Franc
    Franc Member
    Jul 10, 2003
    4,736
    Melbourne North Sub
    FWIW id recommend staying on the grid, plus you get those nice amounts for elec from the govt/retailer :)
    Even without this consideration, going off the grid and your usage overnight would mean you would have to invest in batteries and all the other ancillary stuff to support this..rather than just panels/inverter etc
    The money you spend on this could probably be better economically and enviromentally invested in other ways.
  3. @rt
    @rt Member
    Nov 30, 2005
    2,329
    Sounds like you need to return the power consumption meter.
    It's a very large project to power all of the devices you mentioned.
  4. Jonchilds
    Jonchilds Member
    Jan 9, 2005
    923
    Definitely go for panels and a grid-tie inverter. The money you save on batteries will pay for extra capacity, and you won't waste any solar energy if your batteries are fully charged and not running any appliances. The downside to this is that you still lose power if the grid goes down, even if the sun is shining (for very valid safety reasons).
    Batteries also have a limited life of 2-5 years (depending on usage pattern). Replacing lead-acid batteries every few years isn't really 'green'.
    Grid connected solar is also a reasonably modular enterprise, so you can add extra capacity down the track without too many issues.
  5. -badlad-
    -badlad- Member
    Jan 11, 2010
    124
    Newcastle
    +1
    Grid connection is a no-brainer if you are already connected or close to mains power. I think you are definitely on the right track too with reducing your consumption before harvesting solar power. Are you installing solar hot water as well? This can account for around 30% of your energy usage.
    Yoodaa
    Yoodaa Member
    Sep 25, 2003
    1,668
    Thanks for the input guys.
    This initial project I speak of was to power just my new low voltage laptop and modem.
  7. aXis
    aXis Member
    5,233
    Kalgoorlie, WA
    With the mony you waste setting up a small scale battery system just for the laptop, you may aswell start preparing a low capacity grid tie system, with a big enough inverter to cope with the extra increase in capacity later.
    Any offset power is an improvement, it doesnt have to be connected directly to the laptop to save.
  8. Delator
    Delator Member
    Dec 23, 2001
    2,009
    Far:East:Melb
    the laptop has a battery though :p
    I have too thought about something similar, like getting a cheap ebay solar panel to run a laptop.. just for more of a project
  9. Franc
    Franc Member
    Jul 10, 2003
    4,736
    Melbourne North Sub
    Sealed Gel batteries designed for the purpose can last 15 or so years
  10. RussellK
    RussellK Member
    Jun 11, 2003
    510
    Yeah, I think many missed that. It is true, however, that the various govt. subsidies make it cheaper to grid-connect, as there are no subsidies for off-grid (that I know of).
    If you want to futz a little with solar power, your laptop might be a good starting point.
    You say it draws 15W, while the ADSL modem draws 7W, so 23W. What you haven't mentioned is how many hours a day you want to use both. That plus the power draw will determine how many watt-hours you need a day. Also, you need to know how many of those hours will be after dark, as this will determine what battery capacity you need.
    At a very under-thought guess, I'd say you want something like 40W panel (panels cost about $6 per watt) maybe 3 x 7AH 12v sealed lead acid batteries ($18 a pop) a solar regulator to go between the two (MPPT would be nice), and switching voltage converters to power your laptop and modem (I would not use a 240v inverter for efficiency reasons).
  11. 3stars
    3stars Member
    Aug 11, 2006
    4,446
    sorry for the highjack, but where do you get those batterys that you speak of.
  12. Goth
    Goth Grumpy Member
    Jun 22, 2002
    9,228
    /dev/null
    12 V 7 Ah is a very common size for SLAs, get them at Jaycar or many other places.
  13. paulvk
    paulvk Member
    Mar 10, 2010
    1,058
    Solar power will take 20 plus years to just to pay for the cost of the system better to put the money into reducing power consumption eg double glazing, insulating roof walls and floor, you can also get off peak heating for the home. I have a 4 bedroom home with wall and roof insulation during summer a 1hp and 1.5hp aircons keep it cool I was told I would need twice this!
    And just some info 185watt solar for $770 = $4.16/watt
  14. Franc
    Franc Member
    Jul 10, 2003
    4,736
    Melbourne North Sub
    Not with pfit though...
  15. teno45
    teno45 Member
    Dec 27, 2009
    219
    Wagga Wagga
    where did you come up with that number? a couple guy from work have recently got solar panels, and one guy got a credit for over $250 after his night time usage and gas usage. from that one three monthly bill, he calculated around 4 years to pay off his system.
  16. 3stars
    3stars Member
    Aug 11, 2006
    4,446
    not for 18 dollars you don't
    Yoodaa
    Yoodaa Member
    Sep 25, 2003
    1,668
    I was planning on spending $1000 on this solution.
    My thoughts were to buy a 200 Watt panel or so (it can be used once I expand system also).
    As for the rest of the components and costs, I have no idea.
    My laptop battery runs for 8 hours which is a working day for me. So I need, at a guess, 4 hours of charge time which is very generous which the solar setup will provide.
    The laptop will be charged off a car 12V charger so no need for inverter, and the modem runs off 12V anyways.
    So I need to run 7 Watts 24/7
    30ish watts for 4 hours of night
  18. Privatteer
    Privatteer Member
    Mar 19, 2006
    799
    Add a extra 30% to your figures you got from your power meter.
    Those cheap pieces of **** are not accurate with switch mode power supplies.
    They are a bit closer if you have a new power supply with PFC.
    As an example my PC reads at 210W, real usage is 375W using a proper true rms meter.
    Try this site its not too bad for doing an estimation of what size panel, solar regulator etc you need.
    Don't skimp on battery size, repeatably draining them flat shortens the lifespan considerably.
  19. FantoM_CircuiT
    FantoM_CircuiT Member
    Oct 21, 2002
    1,052
    For anyone else interested, the new Mac Mini has surprisingly low power usage. Around 8 watts for web browsing. I was pretty shocked - though there's no screen with that
    http://computershopper.com/desktops/reviews/apple-mac-mini-2010-version
  20. paulvk
    paulvk Member
    Mar 10, 2010
    1,058
    1850watt (1.85kw) is 10 x 770 = $7700 for panels say 6 hours a day (being very generous) 1.85 x $0.22 x 6 = $2.44 a day, perfect year 365 days of sun $891.33 dolars over 8 years just to get the panels in a perfect desert. Note the rebates ect only last for less than 10years!
    If you put the money into what I said you could bring your bill to one quarter or less!
