[WORKLOG] Going Hard
Discussion in 'Extreme and Water Cooling' started by radeon_freak, Aug 11, 2017.
  1. radeon_freak
    radeon_freak Member
    Sep 19, 2007
    3,141
    New build time so I'm taking the opportunity to move from soft tubing to hard.
    I've always shy'd away from the whole lighting/ricer theme builds but this time i'll be jumping in feet first (within reason :p).
    Build consists of:
    7700K
    ASUS Strix Z270E
    16gb G.Skill Trident 3200MHz
    ASUS Strix 1080
    Samsung 850 Evo
    WD Black
    NZXT Hue+
    SoundBlasterZ
    Corsair AX1200
    EK-FB Z270E Monoblock
    XSPC 360
    D5 Vario
    Bitspower Water Tank Z-Multi
    Barrow 12mm OD compression fittings
    Barrow PETG tube
    EK Cryofuel - Blood Red
    Having never seen any Barrow gear I was really impressed with the quality and finish on the barrow fittings. The threads are smooth and well machined along with the finish. Also the tripple O-ring design gets a big thumbs up from me.
    Off with the stock heatsinks
    On with the monoblock
    That's it for now but I'll try keep the thread updated as I progress. Next update will be soon as I attempt to bend some tube :lol:
    radeon_freak
    radeon_freak Member
    Sep 19, 2007
    3,141
    Bit of a first and final update lol. Received the last few parts on order and hit the ground running.
    Pump top and bracket in
    Block and backplate on
    Starting to come together
    Tube bending wasn't as painful as I thought it would be. PETG is pretty friendly to work with and forgiving when it comes to heating and bending.
    Tube in, leak testing
    Done and dusted! I chose not to use the RGB lighting apart from the outer case lights due to it blending the tube and taking away the red 'pop' so to speak. Pics really don't do justice.
  3. Paulie_AU
    Paulie_AU Member
    Nov 29, 2013
    3,463
    Nicely done looks good. :thumbup:
  4. maldotcom2
    maldotcom2 Member
    Feb 18, 2006
    1,938
    Looks good. I like white illumination too, it's a classic look. :thumbup:
  5. havabeer
    havabeer Member
    Dec 12, 2010
    4,329
    looks clean as, good work
  6. juzz86
    juzz86 Member
    Nov 15, 2013
    936
    Forth, TAS
    Gorgeous :thumbup:
  7. kEv_
    kEv_ Member
    May 5, 2012
    522
    very nice!
    :thumbup:
  8. terroristone
    terroristone Member
    Apr 16, 2006
    1,872
    Melb 3030
    looks pretty dam good! whats your drain port?
    T1
  9. leithals
    leithals Member
    Feb 23, 2011
    694
    Central Coast 2257
    wow, nice. I love the run from the pump to the GPU. Fantastic.
