Google Nexus 4 Phone - 4.7" Inch, 1280x768 320ppi, S4 Pro, 8MP, HSPA+, 8/16GB..
Discussion in 'Google Android (OS & Devices)' started by Danske, Oct 12, 2012.
  1. Frontl1ne
    Frontl1ne Member
    Mar 10, 2008
    3,886
    11 minute screen time lol.
    Edit: Was playing music last night and this morning over bluetooth though. As well as steam running all morning. And a few calls.
    Danske
    Danske Member
    Oct 27, 2004
    18,355
    Melgoon
    Ah okay. So basically the answer would be yes, since you need root, so updating android = reroot + redo kernel.
    I shall consider it, it's not like we get new versions of android every month or anything :).
  3. James086
    James086 Member
    Mar 25, 2010
    3,017
    Correct, you do need to flash the new version each time there is a new android version and as said, the app makes it really easy. Once you've installed the kernel manually the first time it's as simple as opening the app, tapping "download and flash" then your phone reboots and it's updated the kernel. No data loss or anything. He's done a really good job of that. :thumbup:
  4. kogi
    kogi Member
    Jan 23, 2003
    4,863
    2031
    Has anyone come across an NFC tag on a clip?
    I want to clip one to my trouser pocket so when I pull out my phone it automatically unlocks
    kogi
  5. MUTMAN
    MUTMAN Member
    8,329
    4109
    i thought you needed to unlock to get NFC to work ?
  6. RAtSAcK
    RAtSAcK Member
    Feb 25, 2007
    2,367
    Bundaberg, QLD
    CM10.2 Official Nightlies are now out. Seems stable as hell for me
    Danske
    Danske Member
    Oct 27, 2004
    18,355
    Melgoon
    You could always stick a NFC tag, on a clip :lol:.
  8. kombiman
    kombiman Dis-Member
    Dec 3, 2006
    12,680
    viva brisvegas
    Firstly, any answer to this^
    secondly, updated rom is power friendly
  9. MUTMAN
    MUTMAN Member
    8,329
    4109
    Gotta agree on the battery side of things. Two days easy now - I'm at 68% after 22.5 hours with 1hr50 off voice calls !
    I remember 'pdroid' did the permission thing, root required of course....
  10. RAtSAcK
    RAtSAcK Member
    Feb 25, 2007
    2,367
    Bundaberg, QLD
    Thing that I care about for battery life is screen time. Kombiman, how much screen time did you get with that charge?
    I've noticed with the official CM10.2 nightly, my battery is much better. I'm currently at 70% with just under 1hr screen time after 9 hours. With the unofficial's, I was getting around 16 hours with around 1.5hours screen time.
  11. kombiman
    kombiman Dis-Member
    Dec 3, 2006
    12,680
    viva brisvegas
    There was about two hours screentime with the brightness turned down a fair bit. Some calls too.
  12. tzortst
    tzortst Member
    Dec 14, 2002
    2,061
    what rom are you using?
  13. kombiman
    kombiman Dis-Member
    Dec 3, 2006
    12,680
    viva brisvegas
    Standard JB 4.3
  14. Sledge
    Sledge Member
    Aug 22, 2002
    8,460
    Same here.. and i was at 16% after 3days 16 hours
    only 1.5 hours screentime though :)
  15. MUTMAN
    MUTMAN Member
    8,329
    4109
    well no bad news to report :)
    i noticed the price had dropped to under aud25 :shock:
    add the psu treggs found and thats a tiny qi charger for 35 bucks.
  16. Treggs
    Treggs Member
    May 12, 2006
    706
    Unfortunately the price for those chargers went back up to $19. Glad I grabbed 3 of them when I did.
  17. Dass Booty
    Dass Booty Member
    Aug 11, 2001
    1,698
    Logan, Queensland
    Thanks for that. I'm glad to hear it's still working well and hasn't wigged out. :thumbup:
  18. Deltoid
    Deltoid Member
    May 24, 2003
    9,515
  19. $qwuzzy
    $qwuzzy Member
    Mar 20, 2004
    781
    Anyone want a Diztronic matt black TPU case?
    Got an extra one because my dad wanted a bigger case.
  20. MUTMAN
    MUTMAN Member
    8,329
    4109
    i just ordered a few different cases from DX, so thanks but no thanks :)
    if you want to drive to my place i can lend you a mwt03 for a short time, see if you like it :)
    edit - just for the record, i have no affiliation with DX, not doing off-site reviews or any of that stuff. just wanted to let ocau know of the awesome that is mwt03 :)
