gotheb1ues X6800 testing || 3630mhz dual prime stable || 4101mhz PI 1M
Discussion in 'Intel x86 CPUs and chipsets' started by gotheb1ues, Aug 9, 2006.
  1. gotheb1ues
    gotheb1ues (Banned or Deleted)
    Mar 21, 2006
    391
    SuperPI testing
    Tuniq tower 120, fan at low speed + Fan blowing into side of case...
    4101mhz 1.575v in bios
    Specs.
    X6800
    Gigabyte DQ6
    G.Skill 6400HZ 4-4-3-8
    gotheb1ues
    Mar 21, 2006
    391
    gotheb1ues
    Mar 21, 2006
    391
    Prime ORTHOS 2004 dual testing
    X6800 @ 3630 MHZ 1.412v volt in bios
    Aircooling TuniQ tower 120
  4. bayan
    bayan Member
    Jan 26, 2006
    208
    Geelong, VIC
    looks nice :)
    How about some 3DMark06 CPU test?
    gotheb1ues
    Mar 21, 2006
    391
    sound like a good idea! will do a test soon. will have to do it at stock volt as my ram are passive cooled and have no extra fans blowing air into the system. will try at 3500MHz stock volt and report back. Keep in mind that my OS is full of junk and had a few crashes because of OC'ing.
  6. FluffyDog
    FluffyDog (Banned or Deleted)
    Mar 6, 2006
    119
    enough excuses, lets see what a $1600 cpu goes like :)
  7. bayan
    bayan Member
    Jan 26, 2006
    208
    Geelong, VIC
    Should be ~3300
    gotheb1ues
    Mar 21, 2006
    391
    I think i need to install windows again as i just scored les then what i did with E6400@3200MHZ and the test was done at 3.4GHZ.
    I will have my better air cooling tomorroe hopefully.
  9. bayan
    bayan Member
    Jan 26, 2006
    208
    Geelong, VIC
    What did you get?
  10. Gaidin
    Gaidin Member
    1,952
    Vic
    How come you decided to put the X6800 in the DQ6 and not the P5W?
  11. Multiplexer
    Multiplexer Member
    Feb 26, 2002
    2,127
    Home
    How noisy is the stock CPU fan?
    gotheb1ues
    Mar 21, 2006
    391
    I'm using the tuniQ tower 120 can't hear it at all.
    because my P5W is at my house, and won't be able to test it untill i get home from brisbane next week.
    only 6554 at 3.4GHz 650/1600.
    Just re installed windows and at 3.2GHZ default voltage, 266fsb 12x multi 650/1600 and got 6561
    gotheb1ues
    Mar 21, 2006
    391
    why should it be that expensive? :confused:
  14. EvilGenius
    EvilGenius Member
    Apr 26, 2005
    10,817
    elsewhere
    No no, he means the chip should do 3300mhz...
    Or not... :p
  15. bayan
    bayan Member
    Jan 26, 2006
    208
    Geelong, VIC
    lolz. I was talking about the CPU score of 3dmark06 :)
    what was the CPU score anyhow?
    gotheb1ues
    Mar 21, 2006
    391
    6554 at 3.4GHz || 7900GTX 650/1600. sorry didn't know what you meant by 3300
  17. nVIDIAxp
    nVIDIAxp Member
    Jun 8, 2003
    1,161
    North Shore, Sydney
    he means the CPU score, not the 3dmark score
    gotheb1ues
    Mar 21, 2006
    391
    sorry read it too fast don't normally benchtest the cpu score or take notice.
    It was 2935 at 3400mhz
    Eva got 3368 at 3812mhz
    So not too bad if you ask me. no tweaks at all in windows or 3Dmark06.
  19. Voltus
    Voltus Member
    Sep 20, 2004
    2,724
    Coolangatta
    so dual Orthos stable on air was 3200.. I wonder what would be dual Folding stable on air? do you fold?
    gotheb1ues
    Mar 21, 2006
    391
    I'm running seti@home right now. I will test to see what i can get orthos stable tonight. I'm hoping for 3.4GHZ orthos stable on air at all stock volts in bios.
