GPO Power Meter
Discussion in 'Electronics & Electrics' started by ben_qld, Jul 10, 2007.
  1. Mr Snrub
    Mr Snrub Member
    Sep 14, 2001
    190
    Brisbane, Australia
    I'm a little sceptical of it's accuracy. Hooked it up to my PC (e4300, 965p-DS3, 2 x HDD, 7900GS). Playing Flight Simulator X (which is fairly taxing on CPU and Video), and the whole lot was only drawing 135 watts. With both CPUs at full ball in TAT i manage to squeeze 150w. Hooked it up to my clothes iron and it drew 2250 watts which seems about right. So I am really confused. Anyone offer any insight?
  2. Odje
    Odje Member
    2,298
    Sounds reasonable. Computers don't use as much power as people think.
  3. Gecko
    Gecko Member
    Jul 3, 2004
    2,715
    When I used to do a lot of lanning, we allocated everyone 1 amp, or 240 watts for their computer + monitor, and with that rule of thumb I don't think we ever had issues.
  4. TMM
    TMM Member
    Mar 29, 2005
    7,481
    Congrats, you have learned that all the "you need alteast a 500w PSU" bullshit, is well, bullshit. You need a very, very high end end rig to even just pull over 300W :D
  5. Mr Snrub
    Mr Snrub Member
    Sep 14, 2001
    190
    Brisbane, Australia
    Well I know that a 500w PSU will not draw 500w on its own. I have an Antec NeoHE 430w, and was expecting at least 200w draw based on my components etc.
  6. Iceman
    Iceman Member
    6,647
    Brisbane (nth), Australia
    Yes but you need a very high end power supply to cleanly and consistently deliver even half of it's rated capacity for extended periods ;)
  7. NewKleer
    NewKleer Member
    Jun 30, 2001
    1,494
    and deliver it on the needed rails. to use all that 500W up u need to be using the power in the ratio the psu delivers it...but that often differs from what you need - 12v vs 5v vs 3.3v
  8. z2177199
    z2177199 Member
    Apr 19, 2002
    1,994
    as shown in ocau news page, dans data did a review on it.
  9. TMM
    TMM Member
    Mar 29, 2005
    7,481
    And you base this on...?
    I think you will find most decent brands* will easily deliver at least two-thirds their rated capacity 24/7 for a long time indeed. There are a few exceptions of models that have high failure rates though (the Antec NeoHE, made by Seasonic for example.)
    *Seasonic (inc. Corsair and the Seasonic produced Antec models), FSP (if you go by the true rating rather then 'max'), Silverstone, PCP&C, Zippy to name a few.
  10. nux
    nux Member
    Jan 20, 2002
    16,780
    The bigger problem as stated is having enough current on the rails that you need.
  11. kingmoron
    kingmoron Member
    Dec 22, 2003
    495
    rather interesting picked one up today, dont know if this is the right place to post but...
    3.8ghz q6600, 4gb ram, 8800gtx 675/1050, 150raptor, max load was 340w
    e6300@2.4ghz w/8 x 750gb + 2x 500gb , max load was 320w
  12. NewKleer
    NewKleer Member
    Jun 30, 2001
    1,494
    yeah post results here...what about load vs idle?
  13. kingmoron
    kingmoron Member
    Dec 22, 2003
    495
    gaming pc was about 280watts, didnt check other pc, but only went up a few watts with the array going full access
    ben_qld
    ben_qld Member
    Apr 19, 2002
    1,533
    E4300 @ 2.8Ghz, 2GB DDR, 2 x 320gb 7200rpm, 7900GT, 22" LCD was drawing around 95W @ Idle, and around 110w when playing a game.
    Ben
  15. StratosFear
    StratosFear Member
    8,153
    Melbourne, Australia
    amd 4200 X2 939 @ stock, 1gb ram, x800XT PE, 3 HDD's, drawing ~120 at idle.
  16. Sillen
    Sillen Member
    May 14, 2002
    810
    Melbourne 3130
    Mine arrived today. Idling at ~200W, peaking at 290W with Orthos and Artifact Scan in ATiTool running at the same time. This with:
    E6850 @ 3.5GHz (7x500)1.375v
    P5K Deluxe
    2x1GB Ballistix @ 2.2
    8800GTS
    2x74GB Raptor
    1x200GB WD Caviar SE
    Pioneer DVR-108
    X-Fi XtremeGamer Fatal1ty Pro
    4x80mm Fans through fan controller
    1x120mm Scythe for HS
    Should mention, my UPS is plugged into this so includes Samsung 940B though it only draws 10-15W.
    www.silentpcreview.com/article28-page4.html for some other measurements.
  17. StratosFear
    StratosFear Member
    8,153
    I wouldn't be so sure about that. According to my meter my Samsung 740B draws around 12-15watts when it's in standby.
  18. Odje
    Odje Member
    2,298
    Maybe it was in standby?
  19. Phido
    Phido Member
    Jun 20, 2003
    7,624
    Dark City
    WOW... This thing working right?
    My 80 cm tv, DVD player, VCR, 4x120w sony amp all turned on thumping and glowing away only uses ~55w?!!!
    Yet a 60w globe uses 58w?! So that small globe left on is using more power than all my media entertainment stuff on full blast!?
    My PC uses around 100w on, around 27w off (printer, speakers, crt etc)!! Im switching the power point off from now on!
    My fridge with compressor running uses 700w, but my small airconditioner uses 300w with the compressor going and only 80w with the fan!!!
    Several things used almost no power, mobile charger etc.
    My iron and a hair drier used 1200 w which means they will work fine with my 1500w inverter.
    Wow.
    Basically things use less power than I thought.
    I think I can fit my entire life into a 1500w max draw. With about 1600 W/hr total power daily.
  20. PureFire
    PureFire Member
    Jun 25, 2002
    1,846
    Hooked mine up to PC and it uses 240w idle and 380w in a fps game. I think I might turn the pc off during the day while at work :D
    My TV only used 85w max.
