GPU1 overheating, Please help
Discussion in 'Extreme and Water Cooling' started by Slayer_T, Aug 28, 2017.
  1. Huggy_Bear64
    Huggy_Bear64 Member
    Apr 24, 2010
    3,096
    Melbourne, VIC, 3127
    Is the fan connector just the RPM reporting wire, or does it have all 3 wires for some reason?
    Slayer_T
    Slayer_T Member
    Jul 31, 2013
    63
    Its got all three
  3. Huggy_Bear64
    Huggy_Bear64 Member
    Apr 24, 2010
    3,096
    https://www.ekwb.com/shop/ek-d5-pwm-motor-12v-dc-pwm-pump-motor
    Is this the pump you've got?
    If if is, the fan connector isn't used for power anyway, it's just RPM reporting and PWM signal, so either plug it into your motherboard for that, or you can just unplug it and the pump will run at 100% all the time.
    Slayer_T
    Slayer_T Member
    Jul 31, 2013
    63
  5. Huggy_Bear64
    Huggy_Bear64 Member
    Apr 24, 2010
    3,096
    Slayer_T
    Slayer_T Member
    Jul 31, 2013
    63
    oh right...it looks different
  7. Huggy_Bear64
    Huggy_Bear64 Member
    Apr 24, 2010
    3,096
    So yeah, I don't think you're having pump problems.
    Try turning your pump up to 100% (or unplug it from the motherboard) then move your case around a bunch (lay it on its side, back, upside down, etc.) and see how much air comes out. If that doesn't fix it, you might have to pull the GPU block apart and have a look inside.
    Slayer_T
    Slayer_T Member
    Jul 31, 2013
    63
    I'm starting to believe that too...
    Slayer_T
    Slayer_T Member
    Jul 31, 2013
    63
  10. radeon_freak
    radeon_freak Member
    Sep 19, 2007
    3,155
    Mate you're at the point not where you have no choice but to tear down the loop. It's obvious even without the thermal camera that one gpu isn't getting cooled sufficiently.
    It's either a blockage or a bad mount which I doubt. A bad mount usually results in temps spiking rapidly as there is poor contact with the block. But since you are pulling the loop down there is no harm in checking the mount whilst you're at it.
    Also I'd be going back to series as there is really no reason to run parallel in such a simple loop and a D5. Temp wise you will only be looking at a few degree's difference between GPU's.
    Slayer_T
    Slayer_T Member
    Jul 31, 2013
    63
    I have reconfigured my loop and ran the thermal scanner again and it looks a lot healthier. See Photo / Video
    https://www.youtube.com/watch?v=M4BEjktc3zE
    https://www.youtube.com/watch?v=MLIGG4p7QPM
  12. kEv_
    kEv_ Member
    May 5, 2012
    536
    so its ok now? good work:thumbup:
    what are your temps like?
    my 290x's in series have ~1 degree variance (iirc, that rig is in pieces)
    looks pretty clear to me in that first thermal vid that the flow:
    but you know, i could be wrong...
  13. Flat-6
    Flat-6 Member
    May 1, 2014
    422
    All the thermal scanner is doing is showing you what you already know - ie the first GPU/block has an issue.
    By re-configuring it as a serial connection, all you are doing is masking the problem.
    Pretty much confirms now that you have some blockage issue in the first GPU block.
