GTX 2080ti water cooling EVGA
Discussion in 'Video Cards & Monitors' started by super kermit, Jan 22, 2019.
  1. super kermit
    super kermit Member
    Jun 18, 2002
    1,167
    Sydney Pyrmont
  2. dzajroo
    dzajroo Member
    Dec 23, 2010
    814
    go to that link you posted -> under the pictures you have "overview, Spec,Features, Compatibility, Support -> click compatibility:
    • 11G-P4-2282-KR - EVGA GeForce RTX 2080 Ti XC BLACK EDITION GAMING, 11G-P4-2282-KR, 11GB GDDR6, Dual HDB Fans & RGB LED
    • 11G-P4-2281-KR - EVGA GeForce RTX 2080 Ti BLACK EDITION GAMING, 11G-P4-2281-KR, 11GB GDDR6, Dual HDB Fans & RGB LED
    • 11G-P4-2382-KR - EVGA GeForce RTX 2080 Ti XC GAMING, 11G-P4-2382-KR, 11GB GDDR6, Dual HDB Fans & RGB LED
    • 11G-P4-2383-KR - EVGA GeForce RTX 2080 Ti XC ULTRA GAMING, 11G-P4-2383-KR, 11GB GDDR6, Dual HDB Fans & RGB LED
    • 11G-P4-2384-KR - EVGA GeForce RTX 2080 Ti XC HYBRID GAMING, 11G-P4-2384-KR, 11GB GDDR6, HYBRID & RGB LED
    • 11G-P4-2387-KR - EVGA GeForce RTX 2080 Ti XC2 ULTRA GAMING, 11G-P4-2387-KR, 11GB GDDR6, iCX2 & RGB LED
    too lazy to upload the picture and copy URL.....
    super kermit
    super kermit Member
    Jun 18, 2002
    1,167
    Sydney Pyrmont
    Where in the world can I get one of these?
    EVGA won't post to OZ :(
  4. JoshB
    JoshB New Member
    Feb 1, 2019
    7
    Would also like to know where i can get one. In Australia as well. Can't see it for sale anywhere even over seas
  5. havabeer
    havabeer Member
    Dec 12, 2010
    4,891
    Just use a parcel forwarding service.
  6. JoshB
    JoshB New Member
    Feb 1, 2019
    7
    Oh ok. How is that done. And where can i find this product overseas
  7. havabeer
    havabeer Member
    Dec 12, 2010
    4,891
    Google package forwarding
  8. JoshB
    JoshB New Member
    Feb 1, 2019
    7
    Ok. Where can i purchase the hybrid to forward it to here
    super kermit
    super kermit Member
    Jun 18, 2002
    1,167
    Sydney Pyrmont
    I cannot find one anywhere for the life of me and I am after 2 of them.
    Is this a team/group purchase time?
  10. JoshB
    JoshB New Member
    Feb 1, 2019
    7
    I can't either. I'm wanting one as well. I'm in Oz but even looking overseas and can't find it
    super kermit
    super kermit Member
    Jun 18, 2002
    1,167
    Sydney Pyrmont
    Josh lets chat over Pm and do a team buy
    super kermit
    super kermit Member
    Jun 18, 2002
    1,167
    Sydney Pyrmont
    Woohoo secured supply, how do we organise a team purchase?
    I need numbers before I can get pricing, the more we buy, the cheaper it is.
    JoshB likes this.
  13. havabeer
    havabeer Member
    Dec 12, 2010
    4,891
    You need to talk to ag to get any group buy approvred
  14. JoshB
    JoshB New Member
    Feb 1, 2019
    7
    Sounding promising. Glad you are able to get supply of the kit. Wanting 1 please
  15. thedirkdiggler
    thedirkdiggler Member
    May 19, 2006
    367
    what that is only around 1400, compared to 2k plus . Am I reading this right?
  16. Agg
    Agg Lord of the Pings
    Jun 16, 2001
    31,569
    A Reported Post Near You
    Just a reminder that group buys have to be run by me first to lay out a few ground rules and avoid common problems.. ta.
    JoshB likes this.
    super kermit
    super kermit Member
    Jun 18, 2002
    1,167
    Sydney Pyrmont
    Absolutely Ag, will do.
  18. SKITZ0_000
    SKITZ0_000 Member
    Jul 19, 2003
    1,122
    Tas
    I've purchased an "Alphacool Eiswolf 240 GPX Pro" which will be arriving any day now, it's a 240mm radiator and ended up costing $250AU posted. I decided on this as the better option for me, as the RTX2080 Ti is a very hot card (especially OC with the 380W bios).
    Also regarding mail forwarding, I purchased my Asrock X470 Taichi Ultimate from Newegg US due to no AU availability and used Auspost ShopMate. The whole process was pretty simple but it ended up costing ~ $45 from memory.
  19. JoshB
    JoshB New Member
    Feb 1, 2019
    7
    I've got a Alphacool Eisbaer Extreme 280mm on my CPU so the 240 GPX Pro would connect straight up using the quick disconnects and also I could have a semi custom loop. How did you change bios on a graphics card. I didn't know they had a bios and that you can change it.
    I've got a RTX Titan which is same reference PCB as 2080 ti.
  20. SKITZ0_000
    SKITZ0_000 Member
    Jul 19, 2003
    1,122
    Tas
    Like Pascal, Turing is very sensitive to temperatures, ideally you want to keep it under 50C for best performance. Setting a custom power curve (in MSI after burner or XOC) lets you undervolt the chip a little and effectively stretch the clocks further at warmer temperatures (and lower volts) but over 60C you lose clocks from a secondary temperature curve which you have no control over (and is probably best for stability anyway).
    There is more info in this thread: https://www.overclock.net/forum/69-nvidia/1706276-official-nvidia-rtx-2080-ti-owner-s-club.html
    Basically any reference PCB (with the 300-A chip) can be flashed to the Galax 380W bios just using nvflash (nvflash -6 bios.rom). It makes a fair difference, I was limited to a 325W TDP out of the box and was constantly power capping even at stock clocks.
    I'm not sure if this works for the RTX Titan though.
