gtx680 psu requirement
Discussion in 'Video Cards & Monitors' started by deejeta, Sep 11, 2013.
  1. deejeta
    deejeta Member
    Apr 19, 2012
    362
    Hi all,
    I posting this cause I really dont know if Im right in sternly replying to a certain thread on another forum about the power requirement of a gtx680.
    Here is the forum thread (im deejeta there as well)
    https://teksyndicate.com/forum/build-pc/best-energy-efficient-parts/152623
    Look I know the gtx680 is a pretty efficient card and all but to recommend a 360w unit... my jaw nearly hit the floor.
    Anyways since I dont have a gtx680 to test myself I was wondering if peeps in OCAU land could shed some light on this for me.
    The suggested unit doesnt meet the amp requirements.... Ive had gpu's in the past not even boot on low 12v amp test psu's. ie gtx480.
  2. HeXa
    HeXa Member
    Jul 7, 2001
    10,211
    Canberra, ACT
  3. Jazper
    Jazper Member
    Jul 28, 2001
    2,684
    Melbourne Australia
    With psus, it is always better to overcater than under
    Considering the pricing, I would probably not go under about 600-650w, and knowing my personal requirements, would shoot for 750+, but my requirements are unusual. 600 should be plenty
  4. M0r4h3us
    M0r4h3us Member
    Jul 15, 2001
    1,023
    Brissie/Gold Coast [4205]
    psu's are a funny area, so many people want to save $$$ > quality
    i would suggest a decent brand around a 750-850w(650w min)
    the HX & AX series from corsair comes with 7 years warranty(8 years;1 bonus year if purchased directly from them)
    i personal use only AX series Corsair psu's .. AX850 , 2x AX1200 , 1x AX1200I
    Cheers, Alan.
  5. terrastrife
    terrastrife Member
    Jun 2, 2006
    18,819
    ADL/SA The Monopoly State
    550W will be overkill even with an overclocked Haswell (more power draw than Ivy). A cheaper quality 550W like a Corsair CX would be fine.
    My 430W S12II had no problems with a 480 and 1st gen i7, a 680 draws less still.
    Most PSUs are most efficient at ~80% load, but about 50-60% load is ideal as it will be quieter on the PSU fan. Getting a 750W psu and running well below 500W will make the PSU run at its least efficient range.
    If warranty is the main reason you buy a PSU, then no one can beat Thermaltake's LIFETIME warranty.
  6. walker_2003
    walker_2003 Member
    Jan 15, 2003
    13,884
    older power hungry cards always make people over do it on psu's its scary but on a good brand PSU u can run 2 x 680s and an overclocked pc on 600w no dramas.
  7. phantom220
    phantom220 Member
    Aug 29, 2007
    805
    I'd say you need a 1500W at minimum, if not two. Good luck!
  8. makros2k1
    makros2k1 Member
    Jan 10, 2003
    105
    Rockhampton
    Lifetime warranty means absolutely nothing. Lifetime warranty is just whatever period the manufacturer says is a reasonable lifetime of a product, and in the end they can say its 1yr, 2yr etc etc so you never actually know how long you are covered for.
  9. terrastrife
    terrastrife Member
    Jun 2, 2006
    18,819
    That's a limited lifetime warranty. Lifetime is lifetime, even if your replacement isn't the same one. However you may end up with a different warranty with your replacement.
  10. makros2k1
    makros2k1 Member
    Jan 10, 2003
    105
    Rockhampton
    So you honestly believe it means the warranty lasts until the day you die???
  11. terrastrife
    terrastrife Member
    Jun 2, 2006
    18,819
    How long do you reckon lifetime warranty on some PC133 SDRAM would last for?
    Because I did an RMA this year for some.
  12. WishBone17
    WishBone17 Member
    Nov 21, 2002
    4,565
    Dundas (Sydney)
    just go all out and get 1200i, be done with it. it will last you for many many moons
  13. makros2k1
    makros2k1 Member
    Jan 10, 2003
    105
    Rockhampton
    It's up to the manufacturer, could be 3yrs, 5yrs or 10yrs. That's the whole point, there is no fixed timeframe and the warranty does not last forever, it's up to them.
    To the OP, i'd suggest getting something decent like a Corsair AX860 so you have room to move in the future.
  14. kjparker
    kjparker Member
    1,592
    For what it's worth, The gtx 680 is quite popular in ITX builds, especially in the SG05 case. Max psu available (at least when I built mine) was a 450w. I have been running mine now for about 4 months, and had zero issues.
  15. SpudBoy
    SpudBoy Member
    Jul 30, 2001
    5,316
    Under the Bed.
    this.. great cards these 680s run reasonably cool, arent too loud and dont draw too much power.
  16. M0r4h3us
    M0r4h3us Member
    Jul 15, 2001
    1,023
    thats what i do!
    my daughter runs a AX1200i lol...
    this is ocau afterall...
    cheers, Alan.
  17. WishBone17
    WishBone17 Member
    Nov 21, 2002
    4,565
    Dundas (Sydney)
    and all she plays is facebook and candy crush? hahaha.
    i sold you my blown 1500w a few years ago, do you remember that?
  18. bigfellla
    bigfellla Member
    Oct 14, 2011
    373
    Just my two cents. Really should be talking about amperage and temperature derating. At that point id say for a 680 system not overclocked, 40A on the 12V rail derated is a good idea.
  19. M0r4h3us
    M0r4h3us Member
    Jul 15, 2001
    1,023
    yeah.. long gone..
    no she plays more games than me. eg 100 + hours on skyrim over two seperate accounts ..
    cheers, Alan.
  20. dasa2
    dasa2 Member
    Feb 5, 2003
    1,035
    Northern VIC
    i was running a 4870x2 and q9450 from a pcp&c psu 510w 34a continuous and 38a 650w peak
    gtx680 with 2600k would use half the power of that system
    my watercooled system with 2600k@4.4\7970@1100 was using ~300w at the wall while gaming
    the seasonic 360g has a 30a 12v which should be enough but the one 6\8 pin would make me hesitant to recommend it
    450-550w is the most i would typically recommend for a single gpu system but sometimes the corsair hx 650 with its 7 year warranty looks tempting when it was cheap especially if the user was purchasing from a store with a limited psu selection
