Guide: plugpack selection
Discussion in 'Electronics & Electrics' started by LethalCorpse, Aug 18, 2008.
  1. OP
    LethalCorpse
    LethalCorpse Member
    Mar 23, 2003
    3,766
    Rochester, NY
    I did read your post, and the links you posted, and have already done much further research online. I've also done actual research, the kind with books and libraries and a few years in an educational institution. Refer, again, to my previous post.
  2. HotHed
    HotHed Member
    Aug 3, 2004
    848
    Melbourne, Australia
    Thanks so much for the guide.
    I ordered wahl clippers for the dog. One of the reviews said it had a 120-240V charger.
    It came with a 120VAC to 5VDC 100ma charger. :mad:
    I found an old nokia charger 240VAC to 5.7DC 890ma, and swapped the fittings.
    I'm hoping it does not over charge the battery. (14% higher voltage) :Paranoid:
  3. mikk
    mikk Member
    Oct 9, 2006
    50
    Probably not a concern for a modern device.
  4. schmoove
    schmoove Member
    Oct 13, 2006
    757
    Asia
    I'm looking for a 24v 1.0a linear regulated plugpack form power adapter.
    It's to replace a suspected faulty 24v 1.0a smps power brick on a USB DAC.
    Buggered if I can find one!
    From the OP
    I can find:
    DFU240050D3030 24V 500ma AC to DC Linear Regulated Power Supply
    https://www.atbatt.com/24v-500ma-ac-to-dc-linear-regulated-power-supply-85999.asp
    not enough current
    DFU240115J0590 24V 1150mA AC to DC Linear Unregulated Power Supply
    https://www.atbatt.com/24v-1150ma-ac-to-dc-linear-unregulated-power-supply-86038.asp
    not regulated
    Am I looking for something that doesn't exist? Anybody help?
    Edit:
    scratch that - I'm an idiot - for some reason I was sure it was 1.0a but I've just double checked and it is 0.2a.
    Should be easy to find a replacement.
    Thanks!
    Edit2:
    Nope!
    I'm finding it impossible to find a regulated linear 24v dc adapter.
    12v are easy to find, but nothing above that....I have no idea why that is :(
    And the Jameco one from the link above is only 120v input :mad:
    LethalCorpse
    LethalCorpse Member
    Mar 23, 2003
    3,766
    Rochester, NY
    If it only needs 200mA, the 500mA regulated supply should be fine
  6. schmoove
    schmoove Member
    Oct 13, 2006
    757
    Asia
    It is 120v input, so won't work in my country.
  7. AgB deano
    AgB deano Member
    Jan 31, 2009
    957
    Brisvegas
    There are plenty of high quality 24v uiniversal SMPS on the market but few have enclosures.
    So, frankly, I would use a common and well branded laptop 19.5v universal SMPS and be done with it. I'll bet you a virtual dollar it'll work fine and a lot better than a lot of other junk out there, that'll likely produce a lot more noise than your typical high quality laptop psu.
  8. schmoove
    schmoove Member
    Oct 13, 2006
    757
    Asia
    Thanks for the reply!
    I don't know that much at all about this topic so I'm following the OP and bearing in mind this:
    I'm not keen to try and run the DAC at 19.5v.
    I was looking for a linear regulated supply, as recommended in the OP.
    As a 240VAC input 24VDC linear regulated plugpack form seems to literally not exist in the entire world, I'll just go with a standard, hopefully half-decent 24VDC SMPS.
    Probably this one:
    http://www.devicemart.co.kr/1153410
  9. AgB deano
    AgB deano Member
    Jan 31, 2009
    957
    Brisvegas
    What exact make and model is your USB DAC?
  10. schmoove
    schmoove Member
    Oct 13, 2006
    757
    Asia
  11. AgB deano
    AgB deano Member
    Jan 31, 2009
    957
    Brisvegas
    Interesting read. I can see why these things gained a foothold in a niche market.
    The short and simple - that unit will be fine with a QUALITY 19/19.5v laptop SMPS to drive that FET opamp, which has an input of 4.5-24v, nominally 15v. That's all your ext psu is driving, the usb source powers the DAC and misc parts.
    As well as this, a quality laptop SMPS is going to put out a hell of a lot less noise than both a cheap linear and smps, especially the $10-listed-on-a-random-korean-website kind.
    If you want a quality universal AC 24VDC linear PSU, there are plenty out there, just need to know where to look. element 14 and farnell are a good place to start.
    Alternatively, build your own. It's not that hard, there are actually quite a few kits and tutorials out there in this age of rasberry pi and assorted mobile devices.
    schmoove likes this.
  12. schmoove
    schmoove Member
    Oct 13, 2006
    757
    Asia
    http://au.element14.com/triad-magnetics/wsu240-0500-r13/wall-mount-adaptor-ac-dc-24v-0/dp/2706411
    24v 0.5a
    How do I know if this adapter is smps or linear?
    No filter options for that on the site and I can't see it on the webpage.
    Even the datasheet doesn't specify.
    Can you give me a direct link to one? I can't find a plugpack type one.
    Audio folks sometimes use something like this:
    https://www.ebay.com/itm/STUDER900-...143668?hash=item212ca83bf4:g:IvIAAOSwRDpZm~VV
    But if I'm going to spend USD 50 I might as well buy a new DAC as the tech has moved on a bit since 2007.
  13. dakiller
    8,366
    3844
    Weigh - transformers in linear units will be heavy.
    Input voltage - 100-240v says SMPS, as a linear transformer will only have a single fixed voltage it will work at.
    Looking at that DAC, as AgB deano says, it'll be fine on a lower voltage. Heck, even 12v will be fine here.
  14. schmoove
    schmoove Member
    Oct 13, 2006
    757
    Asia
    Thanks for the replies, I'm learning plenty here.
    I've got a universal laptop psu here, so I guess I can try it on that then.
    One thing that I still don't get though is why would Firestone Audio make the unit 24VDC in if it will work fine on 19VDC or even 12VDC?
    From my experience most other small audio gear like this uses around 9, 12, or 14VDC.
  15. dakiller
    8,366
    3844
    Because the copied the design from someone else that had 24v, or they copied the datasheet schematic that had +/-12v for the opamp, or they plucked it out of thin air and though that will do.
  16. schmoove
    schmoove Member
    Oct 13, 2006
    757
    Asia
    Ran the USB DAC on a universal laptop PSU @ 19v for about a year, then the PSU blew.
    Was always running boiling hot. Didn't when used for a laptop.
    Why? IDK.
    Would I run this DAC on 19v again? No.
    Picked up a 24v 1.0a smps at the junk market today for $2.
    Tests at 24v and bonus it's only the exact right plug size!
    Will give it a listening test with the DAC tomorrow.
  17. whatdoesthisdo
    whatdoesthisdo Member
    Jan 19, 2011
    9,910
    Gold Coast
    Playing around with some LEDs and a raspberry Pi. I want to use one power supply to power both the pi and and the LEDS (2.5a Pi and another 2.5a to power the LED's). Whats the maximum amp power supply can I get?
    Total idiot so please play nice.
  18. NanoDuke
    NanoDuke Member
    Feb 4, 2007
    7,713
    How many LEDs? 2.5A is a lot of power for some lights.
    whatdoesthisdo likes this.
  19. whatdoesthisdo
    Jan 19, 2011
    9,910
    Gold Coast
    70ish. I think I was 0.03 per LED as the calculation, plus some head room.
  20. merlin13
    merlin13 Member
    Apr 12, 2003
    2,126
    back in BrizVegas
    What physical format/size do you want/need it to be, and at what output voltage(s)?
    - PC supplies can be up well over 30 amps and more for the 12 volt rail and a fistful on their 3.3 volt one as well, if you want ridiculous current and can put up with the size of the cube for the install.
    - Laptop supplies are smaller than that for quite a nice power source, but still a bit large for a small job. There's also another serious trade-off using one of those with needing to fiddling the output voltage. Like, the Asus one running this 17" Lappy here is 19-and-a-bit volts for near 9 amps max output - add a suitable or even a few suitable step-down boards and Voila! You then have 3.3 for the Pi and 12 for the LEDs (or wire the LEDs up with appropriate isolation to run at 19 volts...).
    - else I've got some 12 volt power packs smaller than that running 12 volts at 5 amps, the ones usually bundled with the 5 metre LED strips.
    - or I've also got one that's built for running external hard drives with the appropriate USB cable adaptor - 5 volts at a coupla amps and 12 at about an amp.
    And Wall warts? (ie bog-stock Plug into Mains Hole In Wall). Check the data specs after asking Uncle Google etc for who's got what available.
    Hell, USB C Fast Charge ones are often 5 volts and 3 amps if that's enough to do the job for you, if you've game enough to Frankenstein one or two of those into your project, and they're quite small...
