Guitar Hero World Tour Drum Kit On PC (MIDI Controller)
Discussion in 'Musicians' started by johnd16, May 4, 2009.
  1. johnd16
    johnd16 Member
    Apr 18, 2008
    109
  2. Comma
    Comma Member
    Mar 19, 2007
    3,682
    Sadly I have the Wii Version. Grumble.
  3. th3_hawk
    th3_hawk Member
    Jun 4, 2005
    2,073
    Kilsyth 3137
    It's a damn shame they couldn't (or just didn't) make them compatible across platforms. Would be nice to be able to take my Wii version to a mates place with an XBox or PS3 and play along.
    But back to the OP, very nice work. :)
  4. Kow
    Kow Member
    Aug 2, 2001
    4,790
    Redlands, Bris QLD
    awesome will try this out as soon as i get a reciever , do you know if the redoctance midi to usb cable would work?
    johnd16
    johnd16 Member
    Apr 18, 2008
    109
    Yea not supported at the moment unfortunately. The author of the software, Magnus, might in the future find a way to add support.
    Had the drum kit been cross compatible, it would be a lot more fun indeed.
    Thanks, took me a while to make those videos, however I can't take all the credit; Magnus created the PS360 MIDI Drummer which was the key part in getting the drum kit on PC. Coupled with addictive drums, sounds awesome :thumbup: .
    Nope, the MIDI socket on the GH:WT drum kit is for receiving data only.
    Speaking of outlets, it seems the black outlet port is hi-hat pedal controller. Though no one knows how to make us of it. Further discussion on the mater can be found here: http://pctutorialsonline.net/forum/index.php?topic=40.0
  6. ChrisH
    ChrisH Member
    Dec 29, 2003
    3,151
    I am sure that the wii version would be even easier...seeing as it is a bluetooth device and all. Have a look at youtube videos about using wii motes for all sorts of things.
  7. Kow
    Kow Member
    Aug 2, 2001
    4,790
    Redlands, Bris QLD
    where can i get a wireless gaming reciever all the usual spots are out :(
  8. BlackTigerTech
    BlackTigerTech (Banned or Deleted)
    Jan 27, 2008
    61
    2040 Sydney
    You may be onto something here!
    Is there sure a piece of software that would "translate" the bluetooth from the wii kit to Midi-compliant codes? That would be great! :thumbup:
  9. vellanet
    vellanet Member
    Jan 8, 2002
    914
    Blacktown, Sydney
    This is awesome, I was suitably pissed when I found that the midi port on the kit was input only. Have my eyes open for a wireless receiver and then ~45gb of samples to bash through!
  10. ChrisH
    ChrisH Member
    Dec 29, 2003
    3,151
    BlackTigerTech
    Just to show a few:
    johnd16
    johnd16 Member
    Apr 18, 2008
    109
    Hey Kow, I got mine from VPGames.com, located in America. If you google around you might find a coupon. Otherwise, you should be able to find some on ebay.
    I want this:
    ChrisH Edit: Fixed Youtube Video
  12. atomicsushi
    atomicsushi Member
    Nov 23, 2004
    336
    What do you guys reckon of getting the $110 PS3/Wii drumkit from MSY and using it to learn drums connected to the PC(from total scratch)? Bad idea?
    johnd16
    johnd16 Member
    Apr 18, 2008
    109
    I'm not a drummer myself but I wouldn't recommend it. If you're able to get an acoustic kit, get that.
  14. vanjastar
    vanjastar Member
    Nov 3, 2005
    228
    Or an electric drum kit that isn't complete crap. The guitar hero drum kit is too shit to play the game on so it would be complete shit for real usage.
  15. Mettool
    Mettool Member
    Aug 24, 2005
    303
    Mate of mine showed some serious prowess on GH's drums. So I suggested he look at an electric kit (cos we like our synth stuff haha), did our research and it should be here soon ^^
    In terms of getting you off the ground the kit on rock band/gh is good for understanding the coordination and timing needed. Especially compared to the plastic guitars -_-
  16. dermenslof
    dermenslof New Member
    Aug 31, 2009
    5
    can you help me
    hello
    i have currently 2 drum world tour xbox 360 and 1 wireless receiver for windows. I search a solution to use the 2 drums at the same time as your method with drummer ps360 midi drummer, fl studio and addictive drum.
    or with another software more like ps360 midi drummer to use the second drum with velocity transmited.
    currently i use ps360 midi drummer and xpadder 5.4 for the second drum routing
    can you help me? thank you ;)
    [​IMG] [​IMG]
  17. dermenslof
    Aug 31, 2009
    5
    ChrisH Edit: You have royally pissed me off. We have a 10 character rule for a reason, and obviously when people don't reply to your thread, it means people don't know the answer.
    Bumping is not really acceptable outside the trading forums.
    Welcome to OCAU, please input usefully.
    johnd16
    johnd16 Member
    Apr 18, 2008
    109
    I don't have two drum kits myself, but you could try opening two instances of PS360MidiDrummer and set the midi port on one of them to a different port. Otherwise, contact Magnus, the author of the program: magnus.ellinge[at]gmail.com
  19. dermenslof
    Aug 31, 2009
    5
    thank you
    but the 2nd instance does not recognize the 2nd drum kit.
    maybe, because i have only one "wireless Receiver for windows"
    johnd16
    johnd16 Member
    Apr 18, 2008
    109
    That's true, see if you can find another wireless receiver and let us know how it goes.
