HDMI Cables - v2+, Right-angled?
Discussion in 'Audio Visual' started by DavidRa, Dec 21, 2020.
  1. DavidRa
    DavidRa Member
    Jun 8, 2002
    3,090
    NSW Central Coast
    Looking for some sources for right-angled cables (I think I need 270°). Everything I can find on Fleabay/Gurgle/Bong/etc is either only v1.4 (looking for 4k60 at a minimum here) or are little dongles - which I suspect will die after about 12 minutes, possibly taking out the receiver or device ports with them.
    I need to get the receiver closer to the wall, I'm sick of losing space in my living room because the HDMI cables have massive bend radii and fragile connectors.
  2. power
    67,145
    DavidRa
    DavidRa Member
    Jun 8, 2002
    3,090
    NSW Central Coast
    Possibly. How the F do you tell which ones are trustworthy / good enough quality, given they're all $4??
  4. MrSquiggle
    MrSquiggle Member
    Apr 12, 2005
    58
  5. deluxe
    deluxe Member
    Dec 9, 2003
    603
    DavidRa
    DavidRa Member
    Jun 8, 2002
    3,090
    NSW Central Coast
    IDK - when I see products stating "HDMI 2.0 cable" and the description says "HDMI 1.4a" I get nervous... Example: https://www.cablechick.com.au/cables/ultra-thin-1m-hdmi-cable-hdmi-v20-high-speed-with-ethernet.html. Any experience with the ultra-thin cables? They seem to be "safer" bets than Chinese sellers who have 4 total sales to their record.
  7. JSmithDTV
    JSmithDTV Member
    Jun 13, 2018
    9,039
    Algol, Perseus
    The cables don't have version numbers, the devices do;
    https://www.hdmi.org/resource/cables
    But yeah often it's used instead to indicate rated speed to an extent.
    These should be fine unless trying to push more than 18Gbps;
    https://www.amazon.com.au/UGREEN-Degree-Supports-Ethernet-Xbox360/dp/B00LM2TQPK
    https://www.amazon.com.au/UGREEN-Ethernet-Compatible-Nintendo-Playstation/dp/B00LM2TQW8/
    JSmith
  8. pezzy
    pezzy Member
    Dec 8, 2003
    936
    with aliexpress, my goto brand is ugreen. but it looks like they only have 1.4 spec dongles.
