Headache from ultra wide
Discussion in 'Video Cards & Monitors' started by newynut, Nov 25, 2023.
  1. newynut
    newynut Member
    Jul 28, 2006
    868
    in depression over nbn
    I have had this monitor LG 34WP60C-B for the last couple of days.
    So far its great for gaming but browsing and desktop stuff it gives me a headache.
    I have changed the scale of text to 125% and it helps but I wish I had got the 32" 2k one.LG UltraGear 32 Inch Gaming Monitor, QHD IPS 1ms Monitor, 165Hz Refresh Rate, NVIDIA® G-SYNC® Compatibility32GP750-B.
    I wonder if I can swap it. I got it from lg direct.
  2. macktheknife
    macktheknife Member
    Jul 26, 2005
    3,717
    Try splitting your browser windows to two side by side.
  3. Current
    Current Member
    Aug 10, 2021
    2,153
    It's because of a VA panel.
    VA panels give ghosting event subtle ghosting is likely causing the headaches
    I use Dell IPS screens.
    One dell 30" ultrasharp
    one Dell 34" ultrawide
    Both are IPS
  4. mesaoz
    mesaoz Member
    Jan 15, 2015
    10,689
    Try disabling HDR when you’re doing desktop duties, shortcut is win+alt+B
    l_ QuadX_l and macktheknife like this.
  5. straiton
    straiton Member
    Feb 12, 2003
    718
    i have a super UW 5120x1440. Good for my driving sims
    When browsing i don't use the full screen, just two windows open mostly. Means i don't have to move my eyes or head across the screen all the time
  6. groovetek
    groovetek Member
    Oct 19, 2003
    4,284
    I went from 32" 2560x1440 to 34" 3440x1440 to 38" 3840x1600 to 43" 3840x2160 to 49" 5120x1440 then to back to 38" 3840x1600.
    Too bad the 21:9 currently go from 34" and jump up to 45" pretty much; not many 38" 3840x1600 to choose from, but I think it's a great sweet spot for screen real estate, productivity, and flexibility with a variety of content.
    brayway likes this.
  7. The Beast
    The Beast Member
    5,900
    Back down unda.
    How is 38" 3840x1600 better than 43" 3840x2160?
    It's basically the same thing, right? 3840x1600 is just 3840x2160 with a haircut.
  8. groovetek
    groovetek Member
    Oct 19, 2003
    4,284
    On paper yeah similar? In practice definitely quite noticeably different, though definitely each to their own - for me, a 38" can still be mounted reasonably on a monitor arm, is curved for slightly better immersion, so you can bring it in closer to you (including up/down) without having extra vertical slab of monitor physically in front of you.
    Not saying 3840x1600 is a superior resolution to 3840x2160, because it's not, but the combination of the physical form factor while still having a decent-enough resolution works well for my usage anyway.
    Another thing with my 43" 4K display is, often I felt like sitting at the desk I'd have to look upwards abit, which can be slightly fatiguing.
    MUTMAN likes this.
  9. The Beast
    The Beast Member
    5,900
    Back down unda.
    Yes, but with a 16:9 OLED you can just make a custom 21:9 resolution and get the best of both worlds. :lol:
    Take your point on curved being able to be closer and using a smaller monitor arm. I have my 48" on a monitor arm, but it's a monster.
