Headphone Jack on mic
Discussion in 'PC Audio' started by Pr3dator8, May 25, 2022.
  1. Pr3dator8
    Pr3dator8 Member
    Dec 28, 2009
    424
    Ermington 2115
    Potentially a silly question.
    I’ve been playing around with using IEM’s for gaming and I’m looking for a mic solution.
    I like the look of the RODE NT-USB. Can I use the headphone jack on these for in game audio or are these purely there for Mic monitoring?
  2. Zee
    Zee Member
    Oct 27, 2002
    12,066
    SYD/MNL/SIN/SFO
    I don't have that unit, I have a Blue Yeti, but the answer is "yes", as the point is to allow you to hear your voice compared to whatever the background sound is, so you can tell if your settings are right, or if you're too loud or too quiet.
    Z...
    Pr3dator8 likes this.
  3. theSeekerr
    theSeekerr Member
    Jan 19, 2010
    3,765
    Broadview SA
    Yes, Windows sees this as just an ordinary audio output device - it just also has a hardware feature that can mix in the mic audio for monitoring.
    Incidentally, I'd look up some sound samples of the NT-USB vs the NT-USB Mini - in my opinion the newer, theoretically-less-fancy version sounds better.
