Heaphone & Stereo DACs recommendation
Discussion in 'PC Audio' started by Bertross, Nov 15, 2011.
  1. MdMa
    MdMa Member
    Feb 15, 2003
    357
    Melb
    Do you think the X-Fi Platinum Fatal1ty Champion Series (using the front panel head phone input) has enough power to drive my AKG 601's?
    If not, how would I add a head phone amp to the mix, leaving me the ability to use my Klipsch Promedia's (Bash Amp) as they are now which is connected directly the X-Fi?
  2. Mewoo
    Mewoo Member
    Sep 2, 2011
    39
    Earth
    Definitely not.
    get a DAC, connect it to digital out on soundcard, then buy a matrix m stage ora talisman amp (the one that snufkin sells). :thumbup:
    Just buy it all off snufkin :p:thumbup:
    (Huggy_Bear64 posting on Mewoo's acct btw.)
  3. MdMa
    MdMa Member
    Feb 15, 2003
    357
    Melb
    If I was to only get an amp I take it I would have to connect it to my sound card via 3.5mm (from sound card) to RCA's (amp)?
  4. Drubbing
    Drubbing Member
    Apr 26, 2009
    1,720
    It will probably sound pretty ordinary. I know nothing about the fatality, but if someone says it's not good enough, it might not just be a power issue, but also the quality of the signal that you'll be amping. That's why the recommendation to get a DAC.
    3.5/RCA hybrid connections are not ideal either.
  5. Jedi Jezz
    Jedi Jezz Member
    Mar 13, 2003
    938
    As long as the quality of the sound from the XFi via the 3.5mm jack is good enough for you I see no reason why an appropriate headphone amp won't be sufficient. Surely the DACs on the XFi aren't that bad.
  6. MdMa
    MdMa Member
    Feb 15, 2003
    357
    Melb
    The other issue is the X-Fi Platinum doesn't have any optical outs on the card, only on the front panel. I have also upgraded the OPAMP for the main channels (front left and right), if that makes any difference.
  7. Drubbing
    Drubbing Member
    Apr 26, 2009
    1,720
    Well, a head amp won't have an optical in - it's an analogue device. Unless it's a DAC/amp combo.
  8. MdMa
    MdMa Member
    Feb 15, 2003
    357
    Melb
    Here is some info I found over on hardforum... your thoughts?
  9. Drubbing
    Drubbing Member
    Apr 26, 2009
    1,720
    Lots of advertising techno babble. Burr Brown and Wolfson make quality DACs.
    But it's not just about the chip, but what other components are used with it, and how. None of those product listed are 'high end' as claimed, they're at the budget end. The Musiland is possibly the exception.
    THe best test is you ears, and having something you know that is better to compare it with.
  10. MdMa
    MdMa Member
    Feb 15, 2003
    357
    Melb
    And that's the biggest issue of all; no one I know has anything better than me... yet.
  11. EpHeSuS
    EpHeSuS Member
    Apr 4, 2004
    2,963
    Bentleigh, Melbourne
    Haven't really looked through the entire thread - but I've been reading very good things about the Audio GD DAC's. It's another Chinese guy designing and building his own gear that I've only just recently heard of. Definitely worth having a look at them if you're after a reasonably priced DAC or even amp/DAC combo (the NFB-10SE is meant to be great)
    http://www.audio-gd.com/Pro/DACsEN.htm
    Actually in the process of ordering a NFB-3.1 DAC to put into my headphone system. Be interested to see how much of an improvement there is over the Chaintech AV-710 using the Wolfson DAC.
    So after this my chain will be USB -> AGD NFB-3.1 -> Little Dot 1+ w/ OPA2107 and currently Mullard M8161 tubes and soon to be Voshkod 6ZH1P-EV's -> Alessandro MS-Pro's
  12. swong
    swong Member
    May 11, 2005
    461
    I have the NFB-10SE, using them with DT880/600 in balanced mode. :)
    I also have the MS-1 which also make an excellent combo with the 10SE. Wish I could try the MS-Pros or one of the higher end Grado phones with them too though as I really enjoy their sound. If only you were in Sydney!
  13. Lardman
    Lardman Member
    Apr 25, 2007
    4,277
    ACT 2607
    FIIO E17 hitting soon. Headfonia have released some initial impressions and they're saying it's an all round improvement so far.
    http://www.headphiles.org/index.php?topic=3144.0
    Expected price around the 150 mark, apparently.
    Courtesy of Headfonia:
