help a PHP hack
Discussion in 'Programming & Software Development' started by mrturkey, Feb 13, 2018.
  1. mrturkey
    mrturkey Member
    463
    Wodonga, VIC
    I am trying to retrieve some json data from a url based on data in a table. My table has the URL to fetch, the name of the value I want to retrieve.
    Code:
    $data = json_decode(file_get_contents('$row->url'));
    echo $data->$row['valuekey'];  // This isn't quite right...
    What is the correct way to reference what I am trying to do?
    Thanks
    mrturkey
    mrturkey Member
    463
    Wodonga, VIC
    Solved, multiple errors in above.
    Code:
    $cryptodata = json_decode(file_get_contents($row['url']));
    $myvaluekey = $row['lastvaluekey'];
    echo $cryptodata->$myvaluekey;
    blued likes this.
