Help configuring 2nd NIC (10gb sfp link to NAS)
Discussion in 'Networking, Telephony & Internet' started by McRutch, Aug 2, 2018.
  1. McRutch
    McRutch Member
    Jul 10, 2011
    216
    I've setup a 10gb sfp+ link direct from my PC to NAS, and file transfers are great now.
    But it feels like my other network connection that I use for Internet, etc is now a fair bit slower to react.
    Like I open web browser and it'll spin for 10 seconds before opening the google homepage, etc.
    Just wondering if this is something to do with my dns or gateway settings, etc.
    Is my computer looking on the 10gb link for internet first before going back to my 1gb copper?
    Windows 8.1; Broadcomm BCM57711 10gb; Intel I218-V 1gb.
  2. shift
    shift Member
    Jul 28, 2001
    2,942
    Hillcrest, Logan
    What IP settings did you set on the new link?
    If it's just for accessing the NAS, you should have no gateway or DNS specified at all on that link.
    McRutch
    McRutch Member
    Jul 10, 2011
    216
    that might be the problem, I had the NAS' IP set as my gateway & dns on the 10gb link
  4. HSV_Enigma
    HSV_Enigma Member
    Jul 21, 2003
    486
    That is the problem, remove the gateway from the 10g interface and set up a static route to the specific NAS IP via that interface
    McRutch
    McRutch Member
    Jul 10, 2011
    216
  6. shift
    shift Member
    Jul 28, 2001
    2,942
    Hillcrest, Logan
    You shouldn't need a static route, it's a locally attached network.
  7. HSV_Enigma
    HSV_Enigma Member
    Jul 21, 2003
    486
    Perhaps give us details on the error instead of just 'it fails'
    Agreed, I got the impression it was on the same subnet as the other interface. Just access the file sharing by using the IP of the 10gb interface of the NAS instead of the hostname.
