HELP!! First GIG shoot.
Discussion in 'Photography & Video' started by kittycann, May 16, 2009.
  1. kittycann
    kittycann Member
    Dec 31, 2007
    312
    Central Coast, NSW
    Have just been assigned my first gig shoot for tonight. I only have an eos400D with 18-55mm and 75-300mm lens.
    What is my best set-up option? Can't use flash and I only have 3 songs to get it right!
  2. Squeezer
    Squeezer Member
    Feb 25, 2002
    6,869
    A Nifty 50 would be good. You will struggle with the Kit lens unless the Stage is REALLY well lit. Sometimes even ISO 1600 and F/2.8 just dont cut it.
    Make sure you shot in RAW as you can pull up the expsosure a bit without getting too much noise.
    kittycann
    kittycann Member
    Dec 31, 2007
    312
    Central Coast, NSW
    Well with no chance of getting a 50 before tonight, I have to work with what I have....I know his last show I went to he used a lot of red lighting...
  4. jesh
    jesh Member
    Jun 21, 2007
    1,773
    All you can do is crank your ISO, set your aperture as wide as it goes and set your shutter speed to whatever the minimum you can hand hold. With the kit lens I guess you'd start around 1/60th and adjust up or down if you can. With the kit lens it's bloody difficult to get decent gig shots though, so it'll be hit and miss. Good luck, and if you get another chance try and pick up a 50 1.8.
  5. Odourless
    Odourless Member
    Feb 3, 2009
    1,766
    Far North Sunny Melbourne
    You can't use flash? Why not?
    Getting anything good would be pretty much impossible with what you have and no flash.
  6. occxlr8ed
    occxlr8ed Member
    Jan 2, 2007
    2,512
    Three songs, no flash. Pretty standard rule at gigs ;)
  7. Odourless
    Odourless Member
    Feb 3, 2009
    1,766
    I guess i'm probably just used to smaller gigs where flash is accepted.
    If it was a fairly large gig than I don't get why he would have been told at such a late notice?
    kittycann
    kittycann Member
    Dec 31, 2007
    312
    Central Coast, NSW
    No flash for the artist but can use it for crowd shots....
    A 50 is on my shopping list.....
    And I have no idea why only given 4 hours notice...the agent knew yesterday...
  9. Squeezer
    Squeezer Member
    Feb 25, 2002
    6,869
    If its for Faster Louder than 4 hrs notice seems normal these days which is REALLy annoying and a reason why I'm not putting my name down for many gigs these days
    kittycann
    kittycann Member
    Dec 31, 2007
    312
    Central Coast, NSW
    Yeah it was...... sadly 4 hours isn't enough to organise a babysitter who doesn't pull out at the last minute.... so wont be doing the show tonight anymore....
    Not Happy.....
  11. Iceman
    Iceman Member
    6,647
    Brisbane (nth), Australia
    Hey, can I recommend that if you're going to shoot gigs that you either get;
    1) Camera that can produce clean images at high ISO
    and/or
    2) A lens with a high aperture such as the Canon 50mm f1.8 or the Sigma 30mm f1.4 ?
    Failing that, reserve a spot to put your tripod, because you'll need it!
  12. teegman
    teegman Member
    Feb 13, 2006
    94
    Doh, if I'd read this last night I could've lent you a nifty fifty. If you're going to do much gig shooting in the future it's worth having a play around with one first and getting used to how they handle in a live setting.. 1.8 doesn't give you much depth of field to play with, manual focus is pretty much out of the question at that aperture on a 400d and 1.8's auto focus is slow and hunts like crazy in low light.. it's quite the battle lol! I wish I'd gone for the 1.4 from the start.
    kittycann
    kittycann Member
    Dec 31, 2007
    312
    Central Coast, NSW
    What are the Nikon Nikkor 50mm 1.8 lens like? Will they work well with a 400D?
  14. occxlr8ed
    occxlr8ed Member
    Jan 2, 2007
    2,512
    Welll...u wont get AF so keep that in mind.
    Why not stick with the canon 50mm/1.8 II ;)
    kittycann
    kittycann Member
    Dec 31, 2007
    312
    Central Coast, NSW
    I 'm watching a few canon 50mm on ebay....just saw the nikkor at a decent price and wanted to know if it would be worth it....read some okay reports on it.... stll i'd prefer the canon...but budget is very strict....
  16. occxlr8ed
    occxlr8ed Member
    Jan 2, 2007
    2,512
    You'd have to buy a mount coverter as well, so in the end doubt it will be any cheaper!
    Watch the forums for a nifty fifty!
    kittycann
    kittycann Member
    Dec 31, 2007
    312
    Central Coast, NSW
    ahh...okay.....i'll stick with the canon then....
    Thanks for all your help everyone!!!!
  18. JohnnoD
    JohnnoD Member
    Nov 10, 2006
    2,011
    Try talking with local bars and clubs and get some practice before you put your name down for assignments
    kittycann
    kittycann Member
    Dec 31, 2007
    312
    Central Coast, NSW
    When u have 3 kids and short supply of babysitters...not always an option....
  20. JohnnoD
    JohnnoD Member
    Nov 10, 2006
    2,011
    Then why put yourself under the stress of trying to do photography for an event when you don't know what it's like? Doesn't make sense.. Not having a go at you, but you're not making it easy for yourself
