Help getting 3600Mhz RAM running at rated speed - Z490 platform
Discussion in 'Memory' started by ndr2h, Aug 16, 2020.
  1. ndr2h
    ndr2h Member
    Sep 6, 2013
    120
    Hi Guys,
    Just seeking some advice from those with the knowledge on how to get some memory running at it's rated speed of 3600Mhz. So far anything above 3000Mhz and the system fails to boot. Have selected both XMP Profiles and the system will also refuse to boot. Suspect I need to do some manual adjustments but would need a bit of help with that. Any suggestions?
    CPU: i7 10700KF
    Motherboard: ASUS ROG Z490-H
    RAM: Corsair Vengeance RGB Pro CMW16GX4M2K3600C16 16GB (2x8GB) DDR4
    Timings: Manually set 16-18-18-36
    ndr2h
    ndr2h Member
    Sep 6, 2013
    120
    Solved my own problem, was doing everything right just needed the RAM in slots 2 & 4 instead of 1 & 3.....
    Shame41 and Bolter01 like this.
  3. chilli
    chilli Member
    391
    sydney
    You should be able OC those a fair bit if they are Samsung B-die
  4. TerminalVeloCD
    TerminalVeloCD Member
    May 28, 2004
    1,551
    6170
    +1.
    4266-4400 with tight timings isn't out of the question with that bin.
    ndr2h
    ndr2h Member
    Sep 6, 2013
    120
    Thanks to all. These are now running @:
    4266Mhz
    1.380v
    18-19-19-36
    I'm not sure if that is successful? I haven't bothered to push further but seems pretty stable at that mix. All other factors are on auto.
  6. chilli
    chilli Member
    391
    sydney
    ndr2h likes this.
    ndr2h
    ndr2h Member
    Sep 6, 2013
    120
  8. hellaflush
    hellaflush Member
    Aug 22, 2009
    2,133
    Did you end up playing around with these? Were you able to get any good results?
  9. @sia@home
    @sia@home Member
    Aug 6, 2002
    2,504
    Update your bios to the newest one. Read the release notes for the newer bios's, 'improved DRAM compatibility'.
    Bios update got my F4-4000C19 Dual rank B die kits working at their rated speed. It looks like some of the sub timings were way too tight.
    ndr2h
    ndr2h Member
    Sep 6, 2013
    120
    Thanks just curious - did you only read the OP?
  11. @sia@home
    @sia@home Member
    Aug 6, 2002
    2,504
    Yes sorry, didn't read you had the memory in non ideal positions. Anyhow I've tested 4000MHz dual rank B die kits (32gb) in Asus Z490-H and also Asus Z490-F and they both needed a bios update for XMP to work properly.
  12. MattBaneLM
    MattBaneLM Member
    Jul 18, 2020
    3
    Just be aware of your dimm temps with b-die. some kits can get finiky not much overr 32 deg and I see you are there.
    oh and don't trust TB too much, especially the pcb rev
