Help me choose a small high quality stereo system
Discussion in 'Audio Visual' started by vladtepes, Oct 14, 2017.
  1. steffan72
    steffan72 Member
    Aug 9, 2004
    1,066
    if you get one that can stream bluetooth . . . . is there any reason your wife cant use the radio tuner on her mobile phone and stream it to a bluetooth enabled setup. That would open up your options and remove the requirement for fm radio tuner
    vladtepes
    vladtepes Member
    Sep 30, 2015
    3,146
    Brisbane, Qld
    What radio tuner would that be?
    There's a particular local station she likes, not available via internet radio.
    Also of course FTA radio doesn't chew any data !
  3. Holdenkicks
    Holdenkicks Member
    Mar 30, 2003
    1,001
    Central Coast
    Why would you rule out the Yamaha I suggested?
    vladtepes likes this.
  4. Benno1988
    Benno1988 Member
    Oct 30, 2007
    5,454
    My opinion. For someone who really isn't into Audiophile stuff (most people), just choose one of the very popular units, like Bose or Sonos.
    You can get better bang for buck quality with lesser popular kit but you pay the price elsewhere.
    I have Heos gear and Bose and Sonos. It's all fine for what it is. Don't compare to my proper audiophile gear sound wise obviously
    I'd probably go with the Bose or Sonos, the apps etc are better IMO. Heos has been clunky, works, but clunky.
    vladtepes
    vladtepes Member
    Sep 30, 2015
    3,146
    Brisbane, Qld
    The weird thing about the sonos is you need a 2-set if you want to have stereo...
    Seems a waste of time. Why a two room set, why would I want two mono devices...
    I haven't. I didn't realise it had an FM tuner - now I see it does, it's perfect.
    (Well, all but the price but quality costs I understand that).
    Edit: I see quite a few places seem to sell it at $637, with free shipping.
    e.g. https://www.videopro.com.au/p-10238-yamaha-mcrn470-micro-hi-fi-system-silver.aspx
    That's not too bad a price, getting toward my budget. I wonder if anyone can discount a bit further...
    The above link also has the specs laid out in an easy to read manner.
  6. Hi-end Head
    Hi-end Head Member
    Jan 10, 2018
    456
    Ask Eastwood if they can better that price
  7. Scando
    Scando Member
    Mar 12, 2009
    266
    Hi vladtepes,
    I find myself in a similar situation, wondering if you did end up buying the Yamaha?
    Any thoughts?
    Cheers
    vladtepes
    vladtepes Member
    Sep 30, 2015
    3,146
    Brisbane, Qld
    Mate some financial issues cropped up so no I didn't but I had certainly decided to do so.
    Scando likes this.
  9. zanlation
    zanlation Member
    Jun 5, 2003
    49
    Murrays Beach
    I would recommend a raspberry pi setup (as previously suggested). Its a bit DIY, however it is very easy to setup and the quality is worth it for the $.
    1. Raspberry PI 3 B+ ($55) https://www.littlebird.com.au/raspberry-pi-3-model-b-f1990217-84ed-4cd4-a75a-bd1962465bd8
    2. Volumio software (free) - volumio.org. You can control the raspberry pi from your phone
    3. Raspberry PI HAT/DAC (AUD$90 + postage) - The Boss DAC 1.2 from Allo.com
    4. USB stick or portable HD for music files
    5. Active speakers - Audioengine 5+ ($400) or something similar.
    No CD player, but you did want mp3 compatibility. I wonder if you could use a usb CD drive?
    For radio, you could use digital radio streaming via Volumio.
    firey4059 and vladtepes like this.
    vladtepes
    vladtepes Member
    Sep 30, 2015
    3,146
    Brisbane, Qld
    Cheers, though that saves only $100ish compared with the warrantied and one-piece easier for wife to use Yamaha.
    Maybe I'll keep on eye on the yamaha price and see if it drops or there's sale...
  11. alexc
    alexc Member
    Sep 26, 2002
    1,858
    That is a great shame you need OTA options.
    FWIW having two Apple Homepods in stereo, or even one, is a really great compact audio system. Sure it's not cheap and you have to at least have an iPhone. But they are really great.
    And an iPhone with streaming services does almost everything :)
    But I guess nothing beats just turning on the radio for enduring simplicity and reliability :)
    vladtepes
    vladtepes Member
    Sep 30, 2015
    3,146
    Brisbane, Qld
    "Happy wife, happy life".
    firey4059 likes this.
    vladtepes
    vladtepes Member
    Sep 30, 2015
    3,146
    Brisbane, Qld
    So... Silver or black. I can't decide!!!
    vladtepes
    vladtepes Member
    Sep 30, 2015
    3,146
    Brisbane, Qld
    FINALLY have ordered the Yamaha unit.
    Bought it today via the Billy Guyatts ebay store which currently has a 10% discount code "PRIORITY10" bringing the delivered price (free shipping) to just under $550 which is better than available anywhere else.
    Link for anyone else considering one:
    https://www.ebay.com.au/itm/Yamaha-...835897&hash=item364b700034:g:BmsAAOSw4QRcrWd0
    edit: Yes there have been a few -ve feedbacks on this seller in the last month - but many more positive ones. Fingers crossed. I'll let you know
    Cheers all :thumbup::)
    vladtepes
    vladtepes Member
    Sep 30, 2015
    3,146
    Brisbane, Qld
    DId I mention - it arrived quickly and it's great. Cheers :)
  16. Holdenkicks
    Holdenkicks Member
    Mar 30, 2003
    1,001
    Central Coast
    Glad you liked my recommendation.
    vladtepes
    vladtepes Member
    Sep 30, 2015
    3,146
    Brisbane, Qld
    Yep thanks mate :)
