help me with my backup strategy?
Discussion in 'Storage & Backup' started by archie, Oct 28, 2010.
  1. archie
    archie Member
    Mar 26, 2002
    3,809
    western sydney
    hi guys,
    I run a very small office from home.
    I have a file server (win xp software RAID 5 with 3x 1tb hdds) that I would like to backup.
    So I bought 2x 3.5" esata enclosures and stuck a 2tb drive in each (2 backups a week)
    The server is running win xp sp3 with AHCI, and it seems that it has trouble differentiating between the 2 drives everytime they are plugged in & my backups fail, "previous files not found" errors etc
    Any ideas?
    Any other method you guys recommend?
  2. issa2006
    issa2006 Member
    Feb 4, 2006
    3,179
    AUSTRALIA (ADL)
    archie
    archie Member
    Mar 26, 2002
    3,809
    western sydney
  4. Nyarghnia
    Nyarghnia (Taking a Break)
    Aug 5, 2008
    1,274
    Get a USB HDD and ShadowProtect Desktop Edition, set a retention policy and then forget about it.
    Done.
    -NyarghNia
  5. issa2006
    issa2006 Member
    Feb 4, 2006
    3,179
    AUSTRALIA (ADL)
    unable to find the program to firmware flash it (update it) it uses a non standard flash chip/programmer
    a better card is the addtronics card.
    once you flash the update on it.. it supports(better) multi port boxes as well
    ie 1 card 5 units 1 external box..
    but for what you want - 2 e-sata cables to 2 hdd all good..
    note. e-sata support power saving+ on hdd..
    so xp/vista /win7 hdd power down option works..
    (iv set mine for 2 hours then power down hdd)
    (built in o/s)
    but usb3.0 does not.. they just keep on spining...
    http://www.addonics.com/products/host_controller/adsa3gpx1.asp
    this card is updatible(black one got old firmware 2006-i got 1 from deal extreme.
    p.s it support in raid non raid 2tb hdd.. iv got 2 tb plug in 1wd 2tb + 2tb samsunf eco 3
    the sil 3132 support hot swap+ plug n play, even if the rest of the system does not...
  6. mgiannelis
    mgiannelis (Banned or Deleted)
    Jun 28, 2009
    9
    Yes just move to Windows 2008 server and use acronis
